help!?!?! my car wont start, electrical prob...
Old Jun 1, 2002 | 07:21 AM
c1hatch's Avatar
Default help!?!?! my car wont start, electrical prob...
okay, so i accidently touched the positive side of the battery to my firewall & melted a whole. I moved it back & it started up fine, drove it to checkers & parked it in the driveway. later i drove it into the garage.
This morning i get up to start it, i get nothing, like you would when a starter goes out, so i try jumping it & still get nothing.
heres some other things i noticed,
1)when i try to start it, the cooling fan goes on...
2)my afc doent turn on like it usually does...
3)when i jump the starter(jump the wires on the starter), the cooling fan turns on, & the starter doent crank...
4)the fuel pump doesnt prime
5)all the gauge, srs, cel, seatbelts lights come on like they should
[Modified by c1hatch, 3:50 PM 6/1/2002]
Old Jun 1, 2002 | 07:27 AM
DR. ON POINT's Avatar
Banned
Default Re: help!?!?! my car wont start, electrical prob... (c1hatch)
check all ur fuses
Old Jun 1, 2002 | 08:06 AM
c1hatch's Avatar
i had one bad fuse under the hood(backup 7.5 amp), that was replaced, & still nothing. im gunna get new relays.
i hate electrical work
Old Jun 1, 2002 | 08:32 AM
VTC_CiViC's Avatar
Sounds like you fried a relay or fuse somewhere. The AFC get's power from the ECU, when you turn key does your dash light up as usual? Do you hear the pump prime? If not, your ECU isn't powering up (ECU fuse), if so and your AFC still doesn't turn on, check the wiring at the ECU.
Old Jun 1, 2002 | 09:46 AM
c1hatch's Avatar
Default Re: help!?!?! my car wont start, electrical prob... (VTC_CiViC)
nope. the pump doesnt prime, & the fuse for the ecu is fine. I'll check to see if any wiring if fried.
Old Jun 1, 2002 | 10:09 AM
paulzy's Avatar
check the big battery fuse under the hood....the 80amp one that's held in with 2 screws
Old Jun 1, 2002 | 10:37 AM
B16C-RXed's Avatar
Default Re: help!?!?! my car wont start, electrical prob... (Slow_ass_4dr)
Check your pump fuse too, if you aren't getting gas the car won't let itself start...
Old Jun 1, 2002 | 10:57 AM
c1hatch's Avatar
Default Re: help!?!?! my car wont start, electrical prob... (B16C-RXed)
where is the pump fuse????
there is power going to the ECU, & the vafc isnt powering up. I even tried hooking it up directly, still nothing from it. So i removed the vafc.
the 80amp fuse is good. All of the underhood/dash fuses are good.
Old Jun 1, 2002 | 02:51 PM
c1hatch's Avatar
i jumped the fuel pump & that works, & there is power running to the ecu.
Old Jun 1, 2002 | 03:38 PM
tSuperbike69's Avatar
Check your main relay. It is located under the drivers kickpanel. Ussaully by the hood pop.
Old Jun 2, 2002 | 06:12 AM
c1hatch's Avatar
Default Re: help!?!?! my car wont start, electrical prob... (tSuperbike69)
problem solved, It was a bad ground somewhere. I just grounded the motor again & that solved everything
thanks for the help.
wild bill
Honda CR-V & Element
Dec 23, 2016 05:28 AM
jimmy051702
Jul 9, 2011 04:32 PM
cbstudd77
Dec 20, 2006 07:40 PM
egcivic
Nov 20, 2006 05:32 PM
highperboi
Apr 24, 2005 09:52 AM
