Help with misfire problem.
Old Oct 13, 2002 | 02:40 PM
SiSoul's Avatar
Default Help with misfire problem.
I just rebuilt my motor with eagle rods, JE 9:9:1 pistons, with stock boost on the greddy turbo kit on my 99 si. I keep getting a 301 and 302 error which is a misfire in cylinders 1 and 2. You can also hear it missing. The car has a new cap and rotor and the timing is at 14, nothing is wrong with the plug wires as those have been checked. The plugs are the bkr7e or something.
Old Oct 13, 2002 | 02:44 PM
98civicEX's Avatar
Default Re: Help with misfire problem. (SiSoul)
check the fuel set-up...injectors, lines, and so on...
Old Oct 13, 2002 | 06:53 PM
SiSoul's Avatar
should the timing be advanced or retarded?
Old Oct 13, 2002 | 09:36 PM
Flamenco-T's Avatar
retarded under boost...
check your fmu, sounds like a symptom of FMU sticking...
does it happened at vacuum only ? if it is, I am pretty sure it's fmu sticking
Old Oct 13, 2002 | 10:43 PM
shadowdawn's Avatar
Default Re: Help with misfire problem. (Flamenco-NA)
I've been having the same problem, re-checked plug gaps, they are ok.... my plug wires seem ok, used to misfire all four, but for days now its only cyl 1 and 2..... no idea yet, when I take the turbo off I'm going to re-do the injector install and make sure everything is seated correct and all that...
Oh and when you say you can "hear" them misfire, what does that sound like?
[Modified by shadowdawn, 2:44 AM 10/14/2002]
Old Oct 13, 2002 | 11:22 PM
exactvox's Avatar
Try gapping the spark plugs to 0.030-0.032, check the fuel injectors as well.
Old Oct 13, 2002 | 11:35 PM
SiSoul's Avatar
Its advanced at the moment. The plug gap is around .28 to .25. The misfire is very noticeable at idle, at higher revs you can hear it a little. Only when the car warms up. When you 1st start it the car runs fine. After a minute or so it starts to miss. Then the check engine light comes on.
Old Oct 14, 2002 | 07:13 AM
prodrive's Avatar
try replacing your o2 sensor if its fowled it will try to over correct when in open loop untill 3500 rpm . try this and let me know .
Old Oct 14, 2002 | 10:55 PM
SiSoul's Avatar
Default Re: Help with misfire problem. (prodrive)
Primary or secondary 02, and those damn things arent cheap. 250 for one!! Is there a better way to find out what is wrong?
Old Oct 15, 2002 | 04:32 PM
SiSoul's Avatar
I pulled the plugs and they are white as hell. Im running lean and have no clue why. Nothing has changed only rebuilt the motor with je pistons and eagle rods. Clogged fuel filter maybe?
MBlake55
May 16, 2006 05:28 PM
Pete_SI
Jun 18, 2005 08:04 PM
alfee
May 23, 2005 04:30 PM
soon2b
Apr 10, 2004 06:59 AM
s14 si
Jun 4, 2003 05:18 PM
