Help Me!!!!!! PLEASE!!!!
Old Aug 27, 2002 | 10:53 AM
boosted_dc2's Avatar
Default Help Me!!!!!! PLEASE!!!!
I just got done installing my drag III kit on my 94 gsr. It runs very rough at idle. also it spools good until i reach like 5,000 rpm's. Then it feels like a fuel cut or something beacase it stops pulling. i have a vacume line ruunning from the turbo to a turbo xs boost controller then a line from the controller to the wastegate. Is this right???? also i have the BOV vacume line tee-tapped into the vacume line off the back of the manifold. Any help would be SOOOOO appreciated. Also i have a HKS SS bov, when i let of the throttle it sounds like a chitter, like a pigeon. Is this compressor surge or is that how these sound i cant tell where it is coming from. thanks
Old Aug 27, 2002 | 11:28 AM
CovertFI's Avatar
Default Re: Help Me!!!!!! PLEASE!!!! (hooked_up_gsr)
what is your fuel setup like?
Old Aug 27, 2002 | 11:30 AM
X2BOARD's Avatar
Did you mess with the vac lines for the manifold at all ?
Oh... and fuel setup too...
Old Aug 27, 2002 | 11:37 AM
filetofit
Guest
Posts: n/a
The HKS bov does make kind of a funny sound, thats normal.
Old Aug 27, 2002 | 11:54 AM
Ri5e's Avatar
Default Re: Help Me!!!!!! PLEASE!!!! (filetofit)
5,000 RPM feels like a fuel cut....try replacing the spark plugs.
Old Aug 27, 2002 | 12:08 PM
PrecisionH23a's Avatar
Default Re: Help Me!!!!!! PLEASE!!!! (BG Boost)
are your plugs gapped correctly?
Old Aug 27, 2002 | 12:34 PM
Etylorcen's Avatar
Default Re: Help Me!!!!!! PLEASE!!!! (GudeH23a)
Check your fmu...is it on backwards?
Old Aug 27, 2002 | 02:40 PM
i have a vortech fmu 12:1 and right now i have ZEX plugs left over from my nitrous set up. the only non stock aspect of my vacume line set up is the nitrous lines for the zex kit. Also its blowing black smooke at idle, i know its running hella rich but how can i lean it out withou an afc??? thanks for the help
Old Aug 27, 2002 | 02:44 PM
also what vac line should i be tapped into for the BOV??? im in the fuel pressure line right now does it matter???
Old Aug 27, 2002 | 03:57 PM
boostedsol's Avatar
the hks bov makes a bird chirping noise, so i don't think it is compressor surge.
Old Aug 27, 2002 | 06:59 PM
Default Re: Help Me!!!!!! PLEASE!!!! (boostedsol)
so why would my car be running so rich, i mean even at idle its rich. Once i boost though it goes super lean!!!! i havent hooked up my 255 fuel pump yet but im doing that tonight. any help is appreciated, also im blowin smoke out of my exhaust, allot of it and it looks to be black. it didnt smoke at all before,
Old Aug 27, 2002 | 07:06 PM
DIRep972's Avatar
Smarter than you
what does ur fuel system consist of?
Old Aug 27, 2002 | 08:41 PM
Mr. Vapor's Avatar
Default Re: Help Me!!!!!! PLEASE!!!! (DIRep972)
get rid of those ZEX plugs ASAP....i know of THREE people directly that have had their engines fail due to ZEX plugs. seriously dude, get some NGKs in their NOW.
Old Aug 28, 2002 | 12:58 AM
quickspoolin's Avatar
Make sure your fmu is hooked up right and the inline fuel pump is hooked up right and working.
Old Aug 28, 2002 | 02:53 AM
rjardy's Avatar
you have only the stock pump in there right now?
Rob
Old Aug 28, 2002 | 05:09 AM
DC2R714's Avatar
Default Re: Help Me!!!!!! PLEASE!!!! (rjardy)
what injectors are you running (stock?)
Old Aug 28, 2002 | 08:34 PM
Default Re: Help Me!!!!!! PLEASE!!!! (DC2R714)
YEA!!!!!! i fugured it out i feel like such a retard ......i had the damn missing link in backwards!!!! im such an ***. Thanks for all your help and im getting ngk's tommarow. LATER!!!!!!
BoOsTiN Dc2
Sep 28, 2003 08:15 PM
boobstar
Sep 9, 2003 11:13 PM
B18EG6
Aug 28, 2002 05:31 PM
SlowB16
Jan 7, 2002 04:04 PM
echo999
Oct 19, 2001 12:12 AM
