help me pick a turbo
Old May 27, 2008 | 11:44 PM
drSquish's Avatar
Default help me pick a turbo
I have a LS VTEC that I am putting in a 97 civic coupe. I would like to know what turbo I should get to have a good amount of power, but I am more concerned about spool time. I want something that will be spooled anytime I need it, but not loose steam up top. I don't care if I only make 400hp.
The motor is a 84.5mm ERL Darton sleeved B18B with Carrillo K1s, Weisco 10.1:1, Eagle oem crank, race ported and polished b16a head, complete aftermarket valve train, ctr cam, and much more.
Old May 28, 2008 | 09:10 AM
BlAcKo0sI's Avatar
garrett 57trim should be good for your goals
Old May 28, 2008 | 09:48 AM
oneludesol's Avatar
GDD's Dr. Phil?
Community Builder
Default Re: (BlAcKo0sI)
what is your budget?
Old May 28, 2008 | 10:21 AM
ReDemoN's Avatar
DixielandImports Please
Default Re: (oneludesol)
Get a borg warner.
Old May 28, 2008 | 10:28 AM
turbodano's Avatar
Default Re: (ReDemoN)
We have a 57 trim that uses some of the Borg parts. We also have several other option for you. http://www.bullseyepower.com We make alot of out own parts and use the BW compressors and turbine wheels.
Old May 28, 2008 | 10:34 AM
1995Civic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oneludesol &raquo;</TD></TR><TR><TD CLASS="quote">what is your budget?
This is the golden question right here.
Old May 28, 2008 | 11:00 AM
chimmike's Avatar
Default Re: (1995Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1995Civic &raquo;</TD></TR><TR><TD CLASS="quote">
can't be too low, he built a sleeved block for 400whp.
Why spend all that money to sleeve a block and not use it to it's potential? 400whp is a drop in the bucket for a sleeved motor, with carillo rods!
Old May 28, 2008 | 12:14 PM
drSquish's Avatar
I'd be happy with 400 hp if I could have it throughout most of the RPM range; something hard to ask from a large turbo. I really want to make as much power as possible on this setup but I don't want to have noticeable turbo lag.
lets put it this way...I am willing to save as much as I need to get what I really want.
Old May 28, 2008 | 03:07 PM
oneludesol's Avatar
GDD's Dr. Phil?
Community Builder
Default Re: (drSquish)
.63 GT30R
Old May 28, 2008 | 03:39 PM
Schister66's Avatar
Man U FTW
Ask and you shall receive. This is my thread and numbers with the GT3255b. I never pushed it beyond 10.5psi because of the stock MAP sensor. Now that i have a built block, i got the chance to try out a BW S256, but i think with a built bottom end, you should see wonderful results with either the GT3255b or GT3255e. I was seeing full boost by 3800rpm on the street with the setup listed.
https://honda-tech.com/zerothread?id=2052996
Old May 31, 2008 | 08:00 PM
drSquish's Avatar
thanks guys i'll be rocking the GT3255b soon!
22psi
Mar 16, 2008 02:58 PM
blkitegrals
Apr 6, 2004 01:18 PM
DigitalFusion
Oct 30, 2003 11:00 AM
JDM CTR EK
27
Sep 9, 2003 05:09 PM
TurBoTeG
May 23, 2003 11:48 AM
