Help me pick next setup? D16
Old Mar 30, 2004 | 05:29 PM
Pfieff's Avatar
Default Help me pick next setup? D16
I am trying to figure out what I should do for my next setup. Goal is to hit 300whp on a d16y7 with eagle rods/cp pistons.
setup #1 would be a internally WGed gt28rs on a lovefab shorty
setup #2 would be lovefab shorty, t3/t04e 50 trim, .48 a/r and the extra money saved would go for springs and retainers to bring up my stock redline(6800).
Everything would be tuned with hondata s100b with a 2.5" DP back and rc440's maybe bump them up to 550's. Thanks,
Pfieff
Old Mar 30, 2004 | 06:24 PM
Pfieff's Avatar
anyone?
Old Mar 30, 2004 | 06:31 PM
Johnyquest's Avatar
Default Re: (Pfieffdog)
I'd do the head buildup for the extra rev's and go with the t3/t4. The gt28r is a beautiful turbo, no doubt in my mind whatsoever, but the price is outrageous. Don't give in!
Matt
Old Mar 30, 2004 | 06:39 PM
TurboJesse
Guest
Posts: n/a
Default Re: (Johnyquest)
i say you quit being a bitch and get some good head...
Old Mar 30, 2004 | 06:57 PM
blackeg's Avatar
Default Re: (Mpir3)
would you consider doin a mini-me on your motor? i think it might let you get a few more lbs/min flow allowing you to run a lil more boost on that t3t04e and keep it running more efficient and away from the surge limit....
if you can afford it i would get the ol' disco potato i would get that, but a vtec head with a cam ie zex 59300(which is being proven to be good with boost in a thread by sohcmshue) might work very well combined with the t3t4...
just some suggestions....
Old Mar 30, 2004 | 07:03 PM
TurboJesse
Guest
Posts: n/a
Default Re: (blackeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackeg &raquo;</TD></TR><TR><TD CLASS="quote">would you consider doin a mini-me on your motor? i think it might let you get a few more lbs/min flow allowing you to run a lil more boost on that t3t04e and keep it running more efficient and away from the surge limit....
just some suggestions....</TD></TR></TABLE>
your not the first to try to tell him this
Old Mar 30, 2004 | 08:07 PM
Pfieff's Avatar
I considered the mini-me but I want to do something different. You don't really see any high hp y7's out there.
Old Mar 31, 2004 | 07:54 AM
Pfieff's Avatar
anyone else?
Old Mar 31, 2004 | 08:51 AM
Drew Peacock's Avatar
My D16a6 doesn't like to rev very high if I were you I would stick within the stock rev limit.. I run a ballbearing turbo 50 or 55 trim, it hits full boost at around 4500 -5000 in 2nd lower in 3rd but I still wish I could either stay in the gear a little longer or the boost built up faster. It is fine reving to 6800 but I don't really like doing it daily for some reason.. I probably should get my tappets adjusted, it make a rattly noise after 6000rpms.
Old Mar 31, 2004 | 04:59 PM
Pfieff's Avatar
back up
Old Mar 31, 2004 | 05:38 PM
RyanEJ8's Avatar
Default Re: Help me pick next setup? D16 (Pfieffdog)
Option #2 is what I would go with. It's similar to what I'm doing with my D16.
Old Apr 1, 2004 | 03:36 PM
Pfieff's Avatar
keep um coming
WH0R3nEF9
Nov 3, 2005 05:09 PM
pubestripe
Nov 30, 2004 07:01 PM
D@nnY
Sep 19, 2003 06:30 AM
Black DC2
Jun 29, 2003 12:11 PM
