Inline pro T3 5 bolt manifold with S-cover compressor housings?
Does anyone know if you can fit a S-cover compressor housing on the inline pro 5 bolt T 3 flange manifold?
I have now an T3T4E 54 trim on it but I want to know if I upgrade to a bigger turbo that it will fit or not.
Thanks
p.s. Is anyone running a 44mm Tial wastegate in this manifold as well?
Can I bolt on an elbow on the wastegate hole on the manifold and use a TIAL 44mm on this instead of the 38mm wastegate?
Would this control boost better than the 38mm or is it a waste of money to do
Modified by Importracer_001 at 10:50 PM 12/15/2005
Thanks
Re: Inline pro T3 5 bolt manifold with S-cover compressor housings? (Importracer_001)
no, u need a spacer flange in between the turbo and mani, cause i had an sc61 with that mani and it was a tight fit. that was with an e cover
Re: Inline pro T3 5 bolt manifold with S-cover compressor housings? (jdmhonda)
I talked to inline pro about this a month or so ago. they told me they have seen an S cover on them but they said it isn't a good idea to do because the block needs ground so much to make it work.
just get a RLD mani from Ron. they are strong, cheap, and will fit the S cover
if you run a different down pipe as in one that lets you turn the turbo so the cold side is on the drivers side then you can do it, there is alot more space that side, but you cant use the inline down pipe with it.
Boner_Ben
12-11-2006 06:58 PM
