Help me build a Boosted B20vtec
Old Aug 25, 2007 | 09:09 AM
Mr.Blondie's Avatar
Default Help me build a Boosted B20vtec
I am building a B20vtec in a 91 civic hatchback. the block is being worked on by Gord Bush, he's boring it hone deck and balancing it. Should I have it port and polished?. For interals I am puttin in JE 84.5mm low comp pistons with eagel rods stock crank. I am leaving the head, Cams, intake mani and TB stock for now, I also have RC 440 injectors and a custom turbo manifold.
my turbo plan is to go with a Garrett T3/60-1 w/ .82 a/r
COMPRESSOR SPECS:T04S housing flow: 61 lbs/min 781cfm
.70 A/R housing 60 TRIM wheel
TURBINE SPECS:T3
.82 A/R housing HIGH FLOW 76 TRIM stg3 wheel
is that turbo too big for my build? wat size intercooler do I need? and the plan is the car is gonna be DD and drag car. I dont mind the big HP.
your suggestions will be greatly appreciated
thanks
Old Aug 25, 2007 | 12:06 PM
Mr.Blondie's Avatar
Default Re: Help me build a Boosted B20vtec (Mr.Blondie)
anybody?
Old Aug 25, 2007 | 12:09 PM
bigbadboy's Avatar
sounds good just get some 750 or 880 injectors and turn the boost way up. get a good tune. wat EMS are you going to use? and also wat fuel pump are u going to use
Old Aug 25, 2007 | 01:23 PM
Mr.Blondie's Avatar
Default Re: (bigbadboy)
walbro 255 and I am gonna use a P28 chipped and tuned wit Crome wat size FMIC should I use?
Old Aug 25, 2007 | 06:38 PM
b16a4's Avatar
Default Re: (Mr.Blondie)
get a precision
Old Aug 26, 2007 | 10:03 AM
Mr.Blondie's Avatar
Default Re: (b16a4)
how fast will the turbo spool? I dont want sumthing kickin in at 6000rpm but I still want the big hp wit quicker spool and heavy kick
Old Aug 27, 2007 | 01:22 PM
Mr.Blondie's Avatar
help bump
Old Aug 27, 2007 | 02:49 PM
brute's Avatar
How much horsepower are you looking for? To me, the 60-1 is a pretty monster turbo, and if you aren't looking for those numbers, no sense in having extra lag. The numbers may be easily attainable on a smaller turbo.
So like I said, what are your goals?
Old Aug 27, 2007 | 03:39 PM
tokesGTR's Avatar
Anybody notice the glaring lack of SLEEVES?!?!?!
Old Aug 27, 2007 | 08:25 PM
Mr.Blondie's Avatar
Default Re: Help me build a Boosted B20vtec (tokesGTR)
I am not gonna sleave the block yet I am not lookin over 500whp yet so I am good I just wanna hover around 400 but I dont want to be spooling around 6000rpm I want low end like 3500-4000.
Old Aug 28, 2007 | 04:08 PM
tokesGTR's Avatar
A .82 A/R T3/60-1 isn't going to be making much boost at 3500 RPM's, and who told you that stock B20 sleeves were good to 500 WHP? They are way thinner than B18/B16 sleeves, and lots of people crack them just by bolting a mild turbo kit onto a stock motor without a vtec head.
Old Aug 29, 2007 | 09:11 AM
Mr.Blondie's Avatar
I'll take my chances. What Turbo do u suggest? I want sumthing that can give me high Hp but at low rpm
Old Aug 29, 2007 | 11:08 AM
tokesGTR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.Blondie &raquo;</TD></TR><TR><TD CLASS="quote">I'll take my chances. What Turbo do u suggest? I want sumthing that can give me high Hp but at low rpm</TD></TR></TABLE>
Then you're really silly. You'll take chances destroying your entire bottom end and head, as well as potentially wrecking your turbo so you can cheap out on sleeves right now? It's a thousand dollars that could save you 4000 dollars later.
Old Aug 30, 2007 | 11:10 AM
Mr.Blondie's Avatar
my block is already costing me 2 grand including the pistons rods and motor work. to resleave it will cost me antoher 1800.
Old Aug 30, 2007 | 11:32 AM
tokesGTR's Avatar
Exospeed, RS machine, golden eagle, etc. will get it done for a thousand bucks. With the exchange rate being so good for us right now there is no excuse. Point is, you could very easily cost yourself that 2000+ dollar bottom end and more due to a cracked sleeve because you didn't want to sleeve it to start.
Old Aug 30, 2007 | 02:34 PM
b16a4's Avatar
interesting
looseOFFboost
Oct 19, 2008 10:12 PM
BJOnewiper
Nov 29, 2004 07:13 AM
xxxmikenicexxx
Jan 20, 2004 11:45 AM
stnwag0n
Mar 26, 2003 05:06 PM
93B17A
Jul 1, 2002 08:23 AM
