help with mbc.....
Old Nov 1, 2004 | 01:59 PM
h22a193's Avatar
Default help with mbc.....
I have a greddy mbc, just hooked it up, arrow going toward the wastegate from the turbo. Turned the **** to lowest setting as told, and drove the car, and it goes way past 7, going to like 10 before I can get out of it.
I have a delgate mark 2 wastegate, that came with the drag 4 kit?
I dont know what to do please help me/.///////
Old Nov 1, 2004 | 02:24 PM
Turbo E's Avatar
are you sure its hooked up properly AND are you turning the **** the right way?
here's a tip to know which way to turn the ****. blow into the inlet with your mouth, then turn the ****. if the effort needed increases, you are raising the boost.
if it gets easier, you're lowering (toward stock levels) the boost.
Old Nov 1, 2004 | 03:18 PM
h22a193's Avatar
when I blow in, form the compressor side, to the wastegate, I turn the knocb to where I can get any air throw the other side, which is all the way to the left, where the mbc instructions say stock should be, but my wastegate is not even opening, it just keeps going up, at 10 I get out of it quick?
NEED HELP!
Old Nov 1, 2004 | 03:52 PM
h22a193's Avatar
Default Re: help with mbc..... (h22a193)
never mind I found out why, in the directions they told you to turn the **** the wrong way, shame on them....
Old Nov 1, 2004 | 09:57 PM
Turbo E's Avatar
see what happens when your read my post fully?
Old Nov 2, 2004 | 03:34 PM
h22a193's Avatar
^ thanks!
h22a193
Nov 1, 2004 03:53 PM
black98gsr-t
Oct 27, 2004 09:43 PM
tig3rxiong
Aug 4, 2004 06:40 PM
VinceVTEC
Jun 5, 2004 10:33 AM
uneekcrx
Jun 2, 2002 11:59 AM
