help...lowered compression engine
Old Dec 27, 2002 | 09:01 AM
scsi's Avatar
Default help...lowered compression engine
guys...need some help....i rebuild a 00 SI engine to lower compression 9:1, the car is supercharged with Jakson racing....before they install the V-AFC the car was boosting 8psi, but when the dyno came out, only 135 HP on wheel....and the gage show onlr 4-5 psi....the shop said is due to lower compression engine..is it true?
Old Dec 27, 2002 | 09:10 AM
boostin b16's Avatar
Default Re: help...lowered compression engine (scsi)
there is no reason why lowering your compression would lower your boost. you either have a problem with your charger or your pulley. but the shop is crazy to think lowering your comp. would lower your boost!
Old Dec 27, 2002 | 10:51 AM
BudaKai's Avatar
Default Re: help...lowered compression engine (boostin b16)
Actually it's quite possible with a JRSC. They are steady-state type forced induction. As in your boost is always at the same level. If your engine breathes more as in lower compression with forced induction you have to push more air than normal. Which means you need to change pullies to up your boost.
That's one of the reason's people go with turbo. Instead, you can just turn the ****.
Old Dec 27, 2002 | 11:31 AM
I Like Boost's Avatar
Default Re: help...lowered compression engine (tzsir)
only 135 to the wheel = shop fucked up
Old Dec 27, 2002 | 11:39 AM
LsVTeCTuRBo17's Avatar
Default Re: help...lowered compression engine (BEe18SeAONe)
Check your vaccum lines. I have had problems reading boost in the past because of the vaccum lines.
scspeed
Jul 24, 2008 03:53 PM
SiRay13
May 30, 2006 11:48 AM
Renegade
Mar 16, 2006 05:54 PM
PePpeRedDc5
May 22, 2005 09:36 AM
Muckman
Nov 11, 2001 04:34 AM
