GT30R Water Line hook-up?? Where do i drain the water to?
I have a GT30R BB turbo that is water cooled. THis is on a GSR if it makes a diifference. I know that i can tap off the throttle body for a coolant supply but my question is, where do i drain the water to from the other side of the turbo?
I just purchased the water hook up kit from STAN @ Fast-Turbo but that is just the fittings that connect to the turbo so im still a little confused where to drain the coolant to?
Thanks
Thanks
Re: GT30R Water Line hook-up?? Where do i drain the water to? (xtremeness101)
run it back up to the throttle body. it had mine set up like that for the last 2 years with no issues. actually i bypassed my throttle body coolant lines also so i dont have hot coolant going through that also.
Re: GT30R Water Line hook-up?? Where do i drain the water to? (hovic)
this isnt my motor or picture but its the best picture i could find. the yellow arrow pints to the water lines. it will get you close to the correct area on a B-series.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hovic »</TD></TR><TR><TD CLASS="quote">Do you have a pic where to connect the water lines at the TB? I´ve never seen that before..</TD></TR></TABLE>
umm just look underneath your throttle body. there are two lines going to it. bypass em, it just adds un necessary heat to the throttlebody.
Re: GT30R Water Line hook-up?? Where do i drain the water to? (m R g S r)
so basically i can use the coolant going to the throttle body and run that directly to the turbo and then totally bypass the throttle body? Sounds easier than i though as long as there will be no side effect from by passing the throttle body
done
10-14-2005 12:24 PM
