Help Help Help code 43
Old Jul 28, 2002 | 11:52 AM
slid-n-rag's Avatar
Default Help Help Help code 43
Ok guys this is what i got ....Its a 93 dx 4 door with a turboed 95 ex motor...Ive got 255 fuel pump , 98 ls injectors (i think there 240s),12:1 fmu ,a new fuel filter ,2 steps colder plugs and i changed the the fuel reg. but its still a stock joint .Thats all as far as fuel goes. Its runs strong until it warms up (hitting 10 lbs of boost about 5 times) then it throughs a code 43 and it leans out but only under a load....If im at idle it bounces between 1500 and 900 ...1500 being rich and 900 lean......The things that i have done to it so far is change fmu, fuel filter, and the reg. Thankx for your help and all your ideas....
Old Jul 28, 2002 | 11:54 AM
B20-T's Avatar
Default Re: Help Help Help code 43 (slid-n-rag)
i think the ls injectors are to small..i had this code when i had b16 injectors in my turbo b20.and i change them out to a larger size rc 370cc and the code went away
Old Jul 28, 2002 | 04:29 PM
b18b98's Avatar
Your gonna need an inline fuel pump with those injectors to stop the leaning out. If you upgrade to bigger injectors remember to downgrade your fmu to a lower ratio. ex=310cc with 8:1 or 370cc with 6:1 or do the vafc hack with dsm injectors with no fmu.
Old Jul 28, 2002 | 05:59 PM
BoostedSi's Avatar
Default Re: Help Help Help code 43 (b18b98)
10psi with 12:1 fmu is way too much fuel pressure at the rail. Those stock injectors are probably damn maxed out. I would really recommend u stop boosting that much until u get larger injectors. 440s with afc is a good choice..
Old Jul 28, 2002 | 06:28 PM
slid-n-rag's Avatar
Default Re: Help Help Help code 43 (BoostedSi)
Ive got some 440s from a dsm but i was told that i could not run them on a afc because it would run to rich .....
Old Jul 28, 2002 | 07:10 PM
b18b98's Avatar
do a search on this forum on VAFC Hack and it'll explain everything you need to get your car running right.
ALL MOTOR EM2
Nov 27, 2007 12:50 PM
efyou
Apr 1, 2006 01:03 PM
village_idiot
Sep 13, 2004 11:48 AM
im a monster hehe
Feb 20, 2004 09:45 PM
newsense
Jul 6, 2001 11:37 AM
