help gsr build
Old Oct 18, 2013 | 10:18 PM
gsrbuild13's Avatar
Default help gsr build
I am in need of some help please kinda of new to building Honda motors from scratch (I am a big ls2 lsx guy) I am building a b18c1 (gsr) just took the motor to the machine shop an I have a couple questions but lets start with this so you guys have a idea of the power I am looking for an the amount of boost I am shooting for power wise 450-500 boost 20-25 psi this will be a street car but not a daily just bought eagle rods wisco pistons 81.5 mm 9 to 1 compression I am trying to figure out what cams I should use I have been looking at the skunk pro series but i don't know if i should use pro 1s or pro 2s I am going to be using all skunk valves, valves springs, retainers, cam gears. I am also trying to figure out if I can get away with out sleeving the motor I have been told by a couple guys i should either sleeve the motor or leave it alone but have been told not to use a block guard just looking for some extra advise for some guys also any turbo recommendation sorry if i sound like a idiot with all the spelling an grammer mistake thanks
Old Oct 18, 2013 | 11:16 PM
turbohatch96y7's Avatar
Default Re: help gsr build
E85
Gt30
Great tuner for stock sleeves.
Pro1's
10:1 compression.
Old Oct 18, 2013 | 11:38 PM
gsrbuild13's Avatar
yes i will be running e85 might change it up alittle bit what do u mean 10:1 compression i just said i would be running 9:1
Old Oct 19, 2013 | 01:03 PM
$MIKE$'s Avatar
Look at my thread.
E85
Stock sleeves 81.5
10:1 je
Sc61
Itr cams
548whp. 24 psi.
And I can go up ton600hp
Old Oct 19, 2013 | 02:20 PM
phaphon's Avatar
Make sure you have your clearance set up correctly
jazzRS
Mar 4, 2012 10:29 AM
on-site
29
Jan 27, 2012 11:44 AM
93egSLEEPER
Dec 2, 2010 06:56 AM
xKAMILxEK
10
Aug 21, 2009 01:35 PM
mattcivic
15
Feb 21, 2006 09:43 PM
