Help! Getting a CEL and limp mode after going over 5k.
Old Apr 24, 2003 | 07:32 PM
Slammd Sol's Avatar
Default Help! Getting a CEL and limp mode after going over 5k.
I installed my turbo setup 2 weeks ago and everything has been ok since then. I set my SMC+ settings extremely rich cuz i was paranoid about leaning out and blowing my engine. The last few days i have been getting on it to see what my car has with the turbo on. Whenever I go over 5000rpm my power drops big time. And If I keep going with it to 6000-7000k rpm my car goes into limp mode and throws a CEL. MY a/f guage shows in staying rich and my boost stays at 6psi. Can running to rich make me loose a lot of power and throw a CEL and limpmode? I went to the track and my best was a 16.8 ..... Something is not right.
Any input and help would be really great.
SMC+ settings..
idle= 33, 1-2= 36, 2-3= 35, 3-4= 33, 4-5= 31, 5-6= 30, 6-7= 29
Here is my setup: D15b7
- Garrett T3 turbo bolted to HF manifold with 2.5" downpipe.
- 450cc injectors tuned with SMC+.
- Eclipse 2g side mount intercooler.
- TurboXS RFL blow off valve with 2.5" charge pipes.
- Stainless steel AN-3 oil lines and AN-4 coolant lines.
- Homemade boost controller set @ 6 psi.
- Autometer Phantom boost and air/fuel guage.
- 2 1/4" catback exhaust
Old Apr 24, 2003 | 07:44 PM
acman1's Avatar
Default Re: Help! Getting a CEL and limp mode after going over 5k. (Slammd Sol)
ur running the hack rite? if so, ur getting the cel cuz the map is seeing too much voltage. u need to set ur smc to -40 across the board. ur really running way way to rich w/ it set at <35...and thats the reason for the voltage ur map is seeing also.
Old Apr 25, 2003 | 01:55 AM
Slammd Sol's Avatar
bump....
Old Apr 25, 2003 | 10:02 AM
Slammd Sol's Avatar
ttt
Old Apr 25, 2003 | 10:06 AM
genop's Avatar
Default Re: (Slammd Sol)
did you check what code it throws? call me crazy, but that might give you an idea of the problem.
Old Apr 25, 2003 | 10:27 AM
acman1's Avatar
Default Re: (genop)
r u running the hack? if so, the reason for the cel is cuz of the voltage that the map is seeing...ur correction numbers r too high, they need to b something like -40 instead of -35 and -30especially...
Old Apr 25, 2003 | 10:43 AM
Slammd Sol's Avatar
K, I changed my SMC settings to:
Idle: 34
1-2: 38
2-3: 37
3-4: 36
4-5: 36
5-6: 35
6-7: 34
7-8: 33
I dont get the CEL or limp mode anymore, and it pulls much harder over 4500 rpm now. But I am still feeling a slight loss of power around 6000-6200. Could I still be running to rich above 6k?
Old Apr 25, 2003 | 05:31 PM
turbosol's Avatar
You're probably still really rich, I run close to 12psi and my 8k rpm setting is -35.
Old Apr 25, 2003 | 07:15 PM
Slammd Sol's Avatar
Default Re: (turbosol)
Are you using a SMC+ with 450cc's?
Old Apr 25, 2003 | 07:16 PM
civicguy's Avatar
what cel are you getting?im having the same problem
Old Apr 25, 2003 | 07:51 PM
acman1's Avatar
Default Re: (civicguy)
r u running the hack 2, and if so, what r ur settings at?
hondaEg_808
Jun 19, 2010 11:15 AM
Darkane
Jun 16, 2008 08:41 PM
gftgrill
Oct 27, 2005 12:10 PM
illicon2003
Jun 15, 2004 02:21 PM
cu3tip
Apr 10, 2004 11:28 PM
