ZEX Sparkplugs: Good/Bad?
Re: ZEX Sparkplugs: Good/Bad? (Nine)
i would definantly skip the ZEX plugs and use the NGK copper plugs. the NGK's are normally half the cost of the ZEX and work much better.
for ZEX plugs
for ZEX plugs
Re: ZEX Sparkplugs: Good/Bad? (itr206)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 »</TD></TR><TR><TD CLASS="quote"> they are crap , they burn funny and uneven ,.
good ole NGKs are best. </TD></TR></TABLE>
WERD!
WERD!
HELLO,GOOD MORNIN'
Re: ZEX Sparkplugs: Good/Bad? (laughinxxx)
Me personally I didn't like them, but they work. I liked NGK's better. I don't believe in the 3 prong set up. You can only get a spark off 1. I fired my car up then pulled them back out and it fired on 1 side of the spark plug.
Hey, I'm all about Zex, but those plugs pissed me off. My motor was mis-firing with them.
I'm using Denso 2 steps colder now.
i made 434whp with the zex plugs in my car with no problems whatsoever.if they weren't running right in someones car it was probably because of the tune.i have used them in my car,my wife's car and many customers cars and they have worked out great every time.
i had them zex plugs in my accord wagon with nos as soon as i installed them the car didnt run right . i put the plugs on a sparkplug machine and saw that only one side fires so i tossed them and put the ngks back in... the zexs are garbage....
Re: ZEX Sparkplugs: Good/Bad? (t60-1si)
my friend had the zex plugs in his car and one exploded inside...causeing MAJOR damage. another friend had his detonate constantly. i would stay away from them!
i use NGK one step colder....oem is always best way to go.
Re: ZEX Sparkplugs: Good/Bad? (lazerus)
the good ol NGK BKR7E-11's are cheap and do the job well, especially with N2O.
that's what i used with my DP system last year and i had no problems with them.
they're a #7 heat range, which could even be used for turbo also, but a #8 heat range would be better for most turbo appl. only $2 each average selling cost, sometimes you can find them for less than that too.
Re: ZEX Sparkplugs: Good/Bad? (HybridcivicLS-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridcivicLS-T »</TD></TR><TR><TD CLASS="quote">Me personally I didn't like them, but they work. I liked NGK's better. I don't believe in the 3 prong set up. You can only get a spark off 1. I fired my car up then pulled them back out and it fired on 1 side of the spark plug.</TD></TR></TABLE>
The intent behind the mulitple grounds is to provide more sources for the spark to jump to. It's only going to jump to one ground. It's not designed to have three different sparks.
mine melted anyways so i don't use them..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lazerus »</TD></TR><TR><TD CLASS="quote">NGK iridums are some good plugs if you have some money to burn.</TD></TR></TABLE>
