HELP WITH DRAG KIT INSTALL
hey whats up i was wondering if i can get some help on my gen 3 drag kit install on my 97 gsr i was wondering if anyone has pix of there setup or can help me with with the return line for the oil pan IM LOST!!!!!
so i was wondering if someone can help me out and get me some pics
so i would appreciate it if i can get some help on tapping the oil pan!
thanks a lot
thanks a lot
for your oil pan, you need to have the oil return line TIG welded. When your manifold and turbo are on, eyeball where the oil return line needs to be on your oil pan then mark the pan. drill a hole in it. clean it up nicely then take it to a shop and have it tig welded. this might be some help for you....
http://people.clemson.edu/~averma/Pr...urbo/turbo.htm
do it right the first time. ask DUSTIN for a link to his website. he has a lot of pics on his installation. im pretty sure he has a few shots of the return line.
yeah i would mount everything to make sure yor return line has a clear path. i wouldnt recommend this but i used jb weld on my oil pan. i dont have leaks so i guess i'm lucky.
