Help to diagnose engine whine
Old Oct 9, 2003 | 07:44 PM
Hoodwinked's Avatar
Default Help to diagnose engine whine
hey,
I posted a while ago regarding this problem but no problem found. I made another video that I beleive shows the whining better. You can hear it on the from about 0:02 to 0:03. Its a short almost, grinding/whining sound. Turn up your volume and use headphones if possible
heres the link:
http://www.hephaestusnetwork.c...t.avi
thanks!
Old Oct 9, 2003 | 07:51 PM
DaveF's Avatar
Default Re: Help to diagnose engine whine (Hoodwinked)
that sound clip isnt really the best...
you might have better luck with the hood open in front of the car..make a longer clip as well. that would help alot.
Old Oct 9, 2003 | 08:09 PM
Hoodwinked's Avatar
Default Re: Help to diagnose engine whine (2.2Lcivic)
it is hard to do that when the car is moving, that is also somthing I should have mentioned, it onyl does it when you are in gear, moving, in nuetral just revving it doesnt do it
Old Oct 9, 2003 | 09:35 PM
Hoodwinked's Avatar
bump
Old Oct 9, 2003 | 11:11 PM
tb_pimpjuice's Avatar
You ever hear that whining for a few seconds after you turn your car off? I notice it sometimes. Sounds kinda high pitched, not really grinding tho.
Old Oct 10, 2003 | 04:40 AM
intekragsr's Avatar
Default Re: Help to diagnose engine whine (tb_pimpjuice)
hmm i notice a whine on my engine......bump
Old Oct 10, 2003 | 06:25 AM
turbohappy's Avatar
Default Re: Help to diagnose engine whine (intekragsr)
If it doesn't do it in neutral, I'd have to guess something in the drivetrain or maybe in the turbo. Not that that helps much
Old Oct 10, 2003 | 07:19 AM
Chrome Pipes's Avatar
Default Re: Help to diagnose engine whine (turbohappy)
I didn't hear the sound clip but I've heard an overly tight timing belt whine before..
Old Oct 21, 2003 | 08:29 PM
Hoodwinked's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tb_pimpjuice &raquo;</TD></TR><TR><TD CLASS="quote">You ever hear that whining for a few seconds after you turn your car off? I notice it sometimes. Sounds kinda high pitched, not really grinding tho.</TD></TR></TABLE>
i hear that sometimes too, its like the car is "farting", if you will. i have no clue what it is, i hear it UNDER the car alot better than on the outside of the car tho.
i cant for the life of me figure out what the noise is tho....o well...if it aint broke dont fix it.
zeplin
16
Dec 31, 2008 07:22 AM
bashir26
18
Apr 21, 2008 11:56 AM
MeatballHB
Nov 29, 2005 02:09 PM
HavokB18
Jul 9, 2005 05:17 AM
