Help to connect MSD Box?
Old Feb 6, 2013 | 09:52 AM
Steeve_Civic's Avatar
Default Help to connect MSD Box?
Could you please confirm me where to connect the 2 wires than come from the MSD box (White and red).
The White go to the White/Blue and the red to the black/Yellow
But this last one need to be connected in the red circle or blue circle on the picture below please?
Thank you
Old Feb 6, 2013 | 12:57 PM
LocoJoe's Avatar
Default Re: Help to connect MSD Box?
Red circle if I remember correctly. I used a small bolt and nut to connect the wire from the MSD and the wire in the red circle. Little loctite for reasurrance on the bolt and good to go
Old Feb 6, 2013 | 01:42 PM
Turbo-LS's Avatar
Figure one shows you how to wire the MSD box with internal coil and Figure two shows you how to wire the MSD box with External coil
Old Feb 6, 2013 | 11:12 PM
Thank you.
I use a MSD box (digital 6)
After wiring it will be difficult Remove the MSD cap, Unless I make connectors?
Old Feb 7, 2013 | 02:27 AM
grumblemarc's Avatar
The Grumpiest
Try it and find out.
Old Feb 8, 2013 | 12:38 AM
chrisDavidson's Avatar
dont forget to cut the wires for 4 cyl
Old Feb 8, 2013 | 12:39 AM
drill a small whole in the dizzy cap and put a plug wire on for easy remove
Old Feb 8, 2013 | 09:39 AM
What do you mean please?
Old Feb 8, 2013 | 09:41 AM
There is already a hole on MSD Cap, I need to put 2 plugs wire
Old Feb 8, 2013 | 10:10 AM
LocoJoe's Avatar
The MSD wiring on the plug, has 2 wire loops. Should be blue and pink. They are in a loop because by default its triggered for 8 cylinder engines. You need to cut them both for 4 cylinder engines. After u cut them, isolate them with tape.
Old Feb 8, 2013 | 11:50 AM
Ok thank you, my digital 6 is not brand new and I blue and pink wires are already cut
Old Feb 13, 2013 | 04:15 PM
Ok it works correctly
1994delsolLS
Nov 19, 2009 11:10 AM
Pure Sol
Dec 6, 2005 02:10 PM
kodirtysi
Oct 6, 2005 02:45 PM
ATS*Mark
Aug 8, 2005 05:55 PM
djnikko
Mar 16, 2004 09:46 AM
