HELP co2 injection, intercooler spray bar HELP
Old Nov 1, 2006 | 09:11 PM
Markland Photo's Avatar
Default HELP co2 injection, intercooler spray bar HELP
i tried looking for a nos section but i couldnt so if im at the wrong place please move
hey guys, im installing a nitrous xpress Ntercooler kit spray bar on my intercooler, im not running nos because of the dangers, and want to be a little safer, this kit works with co2 also.
thats what im going to be running, a 10lb bottle of co2.
has anyone here had any experience with co2 injection through intercooler?
any good/bad stories with it, i wont be using it a lot, i more along hte lines of bought it for the cooling factor
any help would be great
-Kevin
Old Nov 1, 2006 | 09:20 PM
WestSideDave's Avatar
Default Re: HELP co2 injection, intercooler spray bar HELP (bulletspastsunset)
http://www.slowboyracing.com/s...=4565
Methonal Injection
Close enough to C02
Old Nov 1, 2006 | 09:23 PM
that helps me wiht how it works, thanks
but still trying to get some imput from people that have used it
Old Nov 1, 2006 | 09:24 PM
Default Re: (bulletspastsunset)
Old Nov 1, 2006 | 10:09 PM
http://www.modacar.com/product....html
c02 kit
Old Nov 2, 2006 | 04:58 AM
EddieCRX's Avatar
Default Re: HELP co2 injection, intercooler spray bar HELP (WestSideDave)
I used C02 fire extinguisher, local company sell off out of date certified units, re-fill is very cheap.
I blast the IC just prior to my run, intake temperature drops very quickly, you will need a friend to spray though.
It’s cheaper than the kits but just as effective, keep it away form the intake.
Used it on 2 race days this year when temps were 30+, I now run NOS, perge during burn out gets things cool pre-launch.
Old Nov 2, 2006 | 08:40 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WestSideDave &raquo;</TD></TR><TR><TD CLASS="quote">http://www.modacar.com/product....html
c02 kit</TD></TR></TABLE>
that what i bought haha
and yeah i like soaking it before a race but anyone do it while driving?
Old Nov 2, 2006 | 09:02 AM
JDogg's Avatar
just make sure the co2 spray bar dosnt spray anywhere near your intake, co2 IN your engine is a BAD thing, co2 displaces oxygen and last i checked oxygen is what makes you go fast
oh, and i have NEVER seen ANY gains by using anything that sprays on the intercooler
Old Nov 2, 2006 | 09:31 AM
well, its not going to be near my intake becuase its... a spray bar, its an oval that connects to the front of your intercooler and sprays co2 to decrease temperature
Old Nov 2, 2006 | 10:18 AM
bump for some experience with it
Old Nov 2, 2006 | 09:46 PM
bump
Old Nov 3, 2006 | 06:51 AM
quicksilver1689's Avatar
i ♥ snails
There was a intercooler spray bar test done by honda-tuning on a 700whp+ h22 turbo drag civic. They gained like 50whp after spraying down the intercooler and getting those iat's down.
Old Nov 3, 2006 | 12:06 PM
radd
but im still takling about lets pretend its nos lol, i want to see if anyone knows about spraying it while running/driving/racing
Old Nov 4, 2006 | 04:34 PM
bumppp
Old Nov 4, 2006 | 05:52 PM
adjsflj
Old Nov 5, 2006 | 07:55 AM
JDogg's Avatar
dur, i know its a spray bar... read what i said... the spray will go through the intercooler and get sucked up into the intake, you know the part before the turbo that usually has a filter attached to it. especially if you have the filter right on the turbo. unless you have a shitty i/c setup the ONLY gains from the nitrous spray bars are from the engine sucking up nitrous
Old Nov 5, 2006 | 10:32 AM
mrrogers1's Avatar
Default Re: (JDogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDogg &raquo;</TD></TR><TR><TD CLASS="quote">dur, i know its a spray bar... read what i said... the spray will go through the intercooler and get sucked up into the intake, you know the part before the turbo that usually has a filter attached to it. especially if you have the filter right on the turbo. unless you have a shitty i/c setup the ONLY gains from the nitrous spray bars are from the engine sucking up nitrous</TD></TR></TABLE>
Can you elaborate on this since it seems that all the products being sold to lower IAT's by spraying on the FMIC's seem to be said to "NOT" do this.
Hell, they are "selling" to "us" but it just seems crazy that they don't do anything more then move the source of injection to the front of the intercooler and make us all think they are doing something they actually are not......
Old Nov 5, 2006 | 10:52 AM
JDogg's Avatar
Default Re: (mrrogers1)
its not their intentions for the intake to suck up the nitrous, just the turbo placement in hondas with the turbo right behind the IC makes this happen. the kits DO lower the surface temp of the i/c, but when i isolate the intake from the residual "cloud" of nitrous the gains disapear.
when you spray the nitrous/co2 onto the intercooler some of it goes though the ic and will form a cloud right behind it, most of the time you can actually see the cloud flow into the turbo. if you use co2 the engine will usually break up and loose a bunch of power b/c the co2 cloud displaces o2 around the intake
Old Nov 5, 2006 | 04:45 PM
oaky that helps a little more haha
i guess from hearing that most / if any gains will be to spray it down while not driving to just lower the temperature
Old Nov 5, 2006 | 05:16 PM
mrrogers1's Avatar
Default Re: (JDogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDogg &raquo;</TD></TR><TR><TD CLASS="quote">its not their intentions for the intake to suck up the nitrous, just the turbo placement in hondas with the turbo right behind the IC makes this happen. the kits DO lower the surface temp of the i/c, but when i isolate the intake from the residual "cloud" of nitrous the gains disapear.
when you spray the nitrous/co2 onto the intercooler some of it goes though the ic and will form a cloud right behind it, most of the time you can actually see the cloud flow into the turbo. if you use co2 the engine will usually break up and loose a bunch of power b/c the co2 cloud displaces o2 around the intake</TD></TR></TABLE>
Thank you very much. That definitely clearly explains it.
jdmyelloweg
Mar 12, 2009 05:10 PM
powerdbygarrett
Jul 17, 2007 07:18 AM
tegmech
Nov 18, 2003 10:18 AM
egg
Jun 13, 2003 09:28 PM
hybrid901
Jun 15, 2002 11:41 PM
