Help with CBR coils on Length
Old Jan 1, 2009 | 03:15 PM
wade's Avatar
Default Help with CBR coils on Length
Seems my CBR coils are about a 1/2inch too short or so. Which year or specific coil is the longer model? I have heard there is a short and a longer version. Thanks guys
Old Jan 1, 2009 | 03:30 PM
wade's Avatar
Default Re: Help with CBR coils on Length
I just measured my coil. It is 5".
Part #: Denso 129700-4510.
Seems I have the short ones. What is the PN for the longer ones?
my coil
Old Jan 1, 2009 | 04:37 PM
boosted hybrid's Avatar
What year are your CBR coils from? Are you using removable tip spark plugs? I have a set of 2001 954rr CBR coils at the shop if you need a set, even have the OEM coil harness with them. PM me if you need them, I'll sell them to you for what i paid for them.
Old Jan 2, 2009 | 01:41 AM
DaveF's Avatar
wade, i belive you have "suzuki" coils there. you need ones from cbr954, like Jeff stated.
here is a pic of what you should be looking for
Old Jan 2, 2009 | 04:44 AM
hybrdthry911's Avatar
if i recall correctly the f4i, and 929 also use the same coils. but the 600rr doesnt, beleive that uses the shorter coil you have. found that one out the hard way.
Old Jan 2, 2009 | 05:47 AM
wade's Avatar
Yes, i am using removable tip plugs. I may have a local source of some, I will let you know.
Thanks for the help.
What is the best removable tip plug for high HP anyways? and is it gonna break the bank for them?
Old Jan 2, 2009 | 05:49 AM
tony1's Avatar
The IK27's are good and aren't TOO bad. If your tune is good, you shouldn't go through them too fast.
Old Jan 2, 2009 | 06:06 AM
wade's Avatar
What plug is a IK27? How much are they and where can I get them, thanks.
Well, after search, it is a Denso plug, heat range 27. That sounds odd
Old Jan 2, 2009 | 06:28 AM
Heat range 27 in the Denso is equivalent to a NGK heat range 8-9. Cheapest i found the 27's online was around 10.00 a plug. Autolite makes removable tip plug that is like 1.50 but only in a heat range 7. I have used them before and work really well.
Old Jan 2, 2009 | 10:34 AM
denso makes k22pr-u plugs that work as well, similar to heat range 7. and not too expensive.
denso compared to ngk
22=7
24=8
27=9
30=10
marcojetpilot
Jul 18, 2007 10:35 AM
1baddcivicsi
Oct 6, 2006 07:35 PM
Suzukii
Aug 14, 2006 10:07 AM
STYLiNxCHiQ_DA9
Jun 22, 2006 02:16 PM
93egryda
Mar 14, 2006 11:27 AM
