help with catch can
Old Jul 18, 2006 | 05:13 PM
Garage 808 Hatch's Avatar
Default help with catch can
i seem to be having a problem with my catch can blowing oil out in my engine bay, i have it hooked up to drain back, but during a run it pukes out some oil onto my distributor, coil, and some other vital ****, i just need a coupla ideas on how to fix it.
Its a boosted B16A on 21 lbs. right now its hooked up to the 2 ports where the hex plugs used to be
Old Jul 18, 2006 | 06:09 PM
A.E Motoring's Avatar
Default Re: help with catch can (Garage 808 Hatch)
u have it mounted high enough to drain back, i thought about that too, so i mounted mine as high as possible and tilted it a lil bit so it can go down the drain back hose better
Old Jul 18, 2006 | 10:19 PM
dunkd's Avatar
wrap a rag around the filter.
Old Jul 18, 2006 | 10:23 PM
ImportMotorSpec's Avatar
Default Re: (dunkd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dunkd &raquo;</TD></TR><TR><TD CLASS="quote">wrap a rag around the filter.</TD></TR></TABLE>
That is about the simplest and easiest fix.
Old Jul 19, 2006 | 09:49 PM
Default Re: (ImportMotorSpec)
did that, soaked it and still went everywhere. although it was not completely covered
J.nguyen
Oct 13, 2006 06:45 PM
Pbanto
13
Aug 30, 2006 04:32 AM
vtech_tuner
Aug 3, 2005 06:27 PM
turbochargeb18c
Jun 19, 2005 02:42 PM
ZUL8R
Nov 18, 2003 06:14 PM
