help cant boost due to speedometer not working code 17
Old Nov 4, 2003 | 08:25 AM
aktuning's Avatar
Default help cant boost due to speedometer not working code 17
i just put a turbo kit on my car over the weekend and now my speedometer doesnt work. so i though it would be the speed sensor but it wasnt because i took off the cap and it still turns and there is votage going to all the wires. now im throwing code 17 which wont let me boost past 4500rpm because i guess the injectors are related to the speedometer so it just cuts everything off like a rev limiter. has anyone every seen a gauge cluster just go bad please help with any ideas or info thanks
Old Nov 4, 2003 | 08:30 AM
turbod16y8's Avatar
Default Re: help cant boost due to speedometer not working code 17 (aktuning)
check your alternator sp fuse..have u messed with your o2 sensor lately?
Old Nov 4, 2003 | 06:16 PM
aktuning's Avatar
Default Re: help cant boost due to speedometer not working code 17 (turbod16y8)
ya i checked all my fuses under my dash and everything is ok and yes i extended my wires for my o2 sensor to reach my downpipe but i dont think that effected my speedometer because it was going up and down crazy for the past 2 weeks and now that im turbo it just stopped
Old Nov 5, 2003 | 07:21 AM
turbod16y8's Avatar
the o2 does effect it. check to see if u have a short in the wires. when i extended mine one of the o2 wires was touching the frame of the car and stop my sppedometer from working. so a search under my name. theres a post about it.
Old Nov 5, 2003 | 03:12 PM
aktuning's Avatar
thanks for info but thats not the problem with my speedometer i checked if there were any loose wires but there is none
Old Nov 5, 2003 | 06:56 PM
turbod16y8's Avatar
im talking about the wires on the o2 sensor.
Old Nov 5, 2003 | 10:07 PM
aktuning's Avatar
help bump vtec dosent some on as well now
Modified by aktuning at 8:02 PM 11/8/2003
Old Dec 8, 2003 | 08:04 AM
95integrags-r's Avatar
any resolution???
Old Dec 8, 2003 | 08:39 AM
B18C4-T's Avatar
Make sure you didin't get any fluids in the speedo sensor(water, anti-freeze, etc). I did a swap and there was moisture in the sensor, I got the same problems. I just blew air into the sensor to dry it out and that fixed it.
JasinC19
Oct 11, 2007 09:47 AM
runitup
May 2, 2004 10:02 PM
senpai
Jan 12, 2003 01:24 PM
Damon B.
Feb 7, 2002 12:20 PM
