Help!! Breather Question.
Old Mar 22, 2002 | 07:34 PM
phildeez's Avatar
Default Help!! Breather Question.
Hey guys,
do any of you have breathers in your car? like the one on the valve cover? I have one and it is spitting oil out everywhere!!!
On the stock motors there is no breather and that hole is connected to the intake. If this was the case wouldn't that mess up the engine if oil is being "sucked" in through the thottle???
I am FI'd so does this make any difference?
thanks,
phil
Old Mar 22, 2002 | 08:04 PM
Ri5e's Avatar
Default Re: Help!! Breather Question. (phildeez)
Hm, looks like you getting lots of blow by.
Old Mar 22, 2002 | 08:19 PM
phildeez's Avatar
Default Re: Help!! Breather Question. (BG Boost)
whats blow by??
sorry im new to this FI stuff.
is this bad???
[Modified by phildeez, 9:20 PM 3/22/2002]
Old Mar 23, 2002 | 02:44 AM
intekragsr's Avatar
messed up piston rings?
Old Mar 23, 2002 | 04:30 AM
Herminator's Avatar
You might want to get a compression check on your cylinders. I'm afraid you will find out 1 or maybe more piston compresion is low due to blown ring landings. Or better known as fubard piston.
Old Mar 23, 2002 | 11:09 AM
philo's Avatar
I would bet almost anything you have a cracked ring landing, same thing happened to me. Do a compression test.
Old Mar 23, 2002 | 05:44 PM
phildeez's Avatar
Default Re: Help!! Breather Question. (philo)
can someone explain why oil comes out of that thing on the valve cover? It would normally be connected to the intake pipe by a hose right???
If so wouldn't oil in the intake manifold be harmful to the engine? or is that hole in the valve cover supposed to suck air IN rather than blow air OUT.
thanks
Old Mar 23, 2002 | 05:47 PM
speedaddict's Avatar
it be valve seals too? I had that same problem with a lot of blow by and my compression tests were all good.
Old Mar 23, 2002 | 05:54 PM
phildeez's Avatar
Default Re: Help!! Breather Question. (speedaddict)
What exactly is "blow by" isn't it when your pison rings are messed up??
i havent done a cp test yet but the boost guage reads at 22 some **** (hgm) i thnk at idle. which is good.
[Modified by phildeez, 6:55 PM 3/23/2002]
lude_dude93
Nov 25, 2013 03:44 PM
xlusiveracer
Sep 7, 2005 04:13 PM
Layziebtnh055
13
Jun 21, 2004 12:21 PM
ritm
Jul 13, 2003 01:55 AM
GruvyTune
Nov 16, 2001 03:54 PM
