help...b16-t.....ls-t
Old May 6, 2007 | 07:16 PM
Pr0j3ctxH@tchx90's Avatar
Default help...b16-t.....ls-t
I recently got a 90 hatch and im looking to make it pretty fast...(low 12's). I have been looking around and i def. wanna go turbo...but i can't decide LS or B16...any one running 12's with this setup..i would love some input...whats cheaper...whats easier to make around 400whp on high boost? and do i have to get pistons/rods to push that kind of power? thanks for any input
Old May 6, 2007 | 09:05 PM
tony413's Avatar
i think you need to search a little more. the main question you should ask yourself is how much am i looking to spend ? am i going DD ? with that being said you need to think about gearing an suspension as those are the main things that get your ET's low
Old May 6, 2007 | 09:21 PM
Schister66's Avatar
Man U FTW
LS turbo....its cheaper and you can always upgrade it with a VTEC head later...
the LS has a longer stroke and more displacement....it would be my choice for the money
Old May 6, 2007 | 09:26 PM
Prism250's Avatar
Default Re: help...b16-t.....ls-t (Pr0j3ctxH@tchx90)
An LS engine will probably be cheaper than a B16. And before turbo it will have more torque also. Go with LS
Old May 6, 2007 | 10:56 PM
Schister66's Avatar
Man U FTW
Default Re: help...b16-t.....ls-t (Prism250)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Prism250 &raquo;</TD></TR><TR><TD CLASS="quote">An LS engine will probably be cheaper than a B16. And before turbo it will have more torque also. Go with LS </TD></TR></TABLE>
unless you get ripped off hard, the LS will be cheaper
Old May 7, 2007 | 03:37 AM
Default Re: help...b16-t.....ls-t (Schister66)
yeah its going to my DD....i searched around last night and am prolly going to go with LS...thanks for the help i will post more when i am starting to recieve the parts...will a t3/to4e be enough for close to 450whp?
Old May 7, 2007 | 06:40 AM
HiProfile's Avatar
For DD, you'll want torque.
For the track...you'll want torque for slicks or a mild setup. B16's with serious traction are easier to bog off the line.
For 400whp, all you need is the right turbo and a good tune - for it to last a week. Rods and pistons are essential for an LS, and you definately want diff pistons in the b16. Many people have done 400whp in a mildly built (pistons/rods) LS, and since you can keep your $1000 in forged/rebuild parts with a vtec head swap, I highly recommend the LS.
Old May 7, 2007 | 10:14 AM
raene's Avatar
You don't need anywhere near 400hp to run 12s. More like 250hp. An LS will do that easily, bone stock.
Old May 7, 2007 | 11:28 AM
Topdawgg's Avatar
Default Re: help...b16-t.....ls-t (raene)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raene &raquo;</TD></TR><TR><TD CLASS="quote">You don't need anywhere near 400hp to run 12s. More like 250hp. An LS will do that easily, bone stock. </TD></TR></TABLE>
exactly...
Old May 7, 2007 | 01:51 PM
Default Re: help...b16-t.....ls-t (Topdawgg)
well if i still want to go 400....would eagle rods and low comp. je pistons do a good job..any other good pistons/rods for turbo setups?
Old May 7, 2007 | 02:31 PM
BOOSTEd2's Avatar
how old are you?
Old May 7, 2007 | 02:46 PM
Default Re: (BOOSTEd2)
haha 15...im tryn to get started young....all my friends can already drive...so im going to make them mad when i have my permit beating them with my mom in the car ...lol
Old May 7, 2007 | 04:42 PM
tony413's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BOOSTEd2 &raquo;</TD></TR><TR><TD CLASS="quote">how old are you?</TD></TR></TABLE>
why does his age matter ?
to OP: now that you know your gonna DD the car now you need to look at tranny choices either keep the stock one an change the final gear OR go with a ITR tranny basically your gonna want to stay in the power range after shifting.
and your choice of eagles and je would be fine the better would probably be
eagle big bolts an arias or cp pistons 9:1 comp with stock head
Old May 7, 2007 | 06:10 PM
Default Re: (tony413)
alright thanks for the help...will valve springs, retainers and sk 2 turbo cams make much of a difference? Are they worth buying?
Old May 7, 2007 | 06:12 PM
BOOSTEd2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony413 &raquo;</TD></TR><TR><TD CLASS="quote">why does his age matter ? </TD></TR></TABLE>
because he needs to get his feet wet before he goes off and tries to make 450whp. he needs to aim at learning to drive a STOCk car correctly first. thats how people get hurt on the street. inexperienced drivers with more hp than they can handle.
Old May 7, 2007 | 06:31 PM
92LSVTEC's Avatar
because he needs to get his feet wet before he goes off and tries to make 450whp. he needs to aim at learning to drive a STOCk car correctly first. thats how people get hurt on the street. inexperienced drivers with more hp than they can handle.</TD></TR></TABLE>
most def agree!!
but on the topic of his car, you can build a boosted LS pretty reasonable. eagle rods, JE... maybe upgraded valvetrain if you have the extra $$
ive seen a few boosted ls making damn good power
Old May 7, 2007 | 06:37 PM
doood's Avatar
been there done that
Default Re: (Pr0j3ctxH@tchx90)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pr0j3ctxH@tchx90 &raquo;</TD></TR><TR><TD CLASS="quote">haha 15...im tryn to get started young....all my friends can already drive...so im going to make them mad when i have my permit beating them with my mom in the car ...lol</TD></TR></TABLE>
have you ever driven let alone ridden in a fwd car with 400whp? do you know how much that is?
honestly, start small. and when you get used to the power then you can shoot for the stars. cause with the attitude you have you're going to hurt yourself.
Old May 7, 2007 | 06:55 PM
Default Re: (doood)
well i plan on driven jus the LS w/ H.I.E , IM for a cpl months...turbo..run on low boost dnt wanna blow anything have bone stock motor..then about a year after i drive get it completly finished, tuned, then hit the track and see what 400 whp feels like ....
Old May 7, 2007 | 08:24 PM
BOOSTEd2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pr0j3ctxH@tchx90 &raquo;</TD></TR><TR><TD CLASS="quote">well i plan on driven jus the LS w/ H.I.E , IM for a cpl months.</TD></TR></TABLE>
i'd hold off on the IM till the turbo was bolted on. you'll lose more power than you'll ever gain.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pr0j3ctxH@tchx90 &raquo;</TD></TR><TR><TD CLASS="quote">.then about a year after i drive get it completly finished, tuned, then hit the track and see what 400 whp feels like .... </TD></TR></TABLE>
i wish it were as easy as that.
Old May 8, 2007 | 08:08 AM
Topdawgg's Avatar
well I agree with the people that say 400whp is too much for a beginner...
I couldnt imagine myself startin out for only a couple months then goin for 400whp...
I drove a D-series for almost a year before I went to a b16 swap...
then another year before I went to boost...
now ive been driving for 4 years now and Im only NOW goin above 400whp...
At least hes sayin he wants to do it at the track
Old May 8, 2007 | 06:24 PM
Default Re: (Topdawgg)
yeah i hate when friends speed on back roads and ****...only way its fun...straight road drag or at the track...got to keep it safe...whats a 400 whp car with a dead driver?
Old May 8, 2007 | 10:33 PM
BOOSTEd2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pr0j3ctxH@tchx90 &raquo;</TD></TR><TR><TD CLASS="quote">yeah i hate when friends speed on back roads and ****...only way its fun...straight road drag or at the track...got to keep it safe...whats a 400 whp car with a dead driver? </TD></TR></TABLE>
exactly. at least you know whats right and whats wrong. im not trying to put you down for wanting to make 400+whp. but just start off slow first and work your way up.
Old May 9, 2007 | 06:29 PM
yeah that sounds good
blk_EK
22
Apr 7, 2007 12:51 PM
draogoon
Apr 28, 2006 07:47 PM
quikB18B
Apr 20, 2004 11:22 AM
grey16
Apr 8, 2003 09:25 PM
