Help with AVC R
Old Dec 25, 2006 | 09:07 AM
VtecnTurbo's Avatar
Default Help with AVC R
i have just installed the avcr into my car and i am having problems with overboosting. i had the big green spring in my 44mm wastegate and with the duty set to .60 @20% the car is seeing peak of 1.27 kg/cm
with the avcr set to off it sees 1.36 kg/cm !!
i then swapped and put in the big yellow spring(approx 10 psi/7.7kg/cm) and the car sees a peak of .82kg/cm/11.6 psi
i never had this problem with my manual boost controller.
can any help me out? i know the avcr is a great unit i am not exactly sure how to use it to it potential. i have searched but could not find a solution
im in the tri state area willing to meet up if any avcr gurus are local.
Modified by VtecnTurbo at 1:53 PM 12/25/2006
Old Dec 25, 2006 | 04:24 PM
Blown90hatcH's Avatar
Default Re: Help with AVC R (VtecnTurbo)
I responded to your PM.....pretty much is has to do with your manifold/wastegate design and the large exhaust side of the turbo. There are a few things you can do to aid....port the wastegate opening, get a smaller spring....run more boost.
Old Dec 25, 2006 | 06:33 PM
VtecnTurbo's Avatar
Default Re: Help with AVC R (Blown90hatcH)
thanks will start with the spring and port when i take off the gate to change the spring . then ill turn up the boost. ill keep you posted
R.A.T.
Apr 8, 2009 05:43 PM
chilli_822
Jul 25, 2008 03:02 PM
CX-T
Jun 19, 2008 09:22 AM
92SiB18C1
Nov 30, 2002 06:34 AM
