Help ASAP with Fmu please
Took apart the FMU to check to make sure its a 12:1 disc and its not, its 10:1 (don't ask, just need help fast). I already have the complete recalib kit and a 12 disc which is the biggest (1 size bigger then whats in there), Now all the discs have a ring that they fit inside that you install the disc with.... BUT the 12 disc which is basically the whole size of the FMU does NOT.... do I use the same ring with the 10 disc (which the 12 disc does NOT fit inside) or do I use no ring at all?
Please help asap thank!!!
Re: Help ASAP with Fmu please (shadowdawn)
NM I installed it with no ring, just the disc and new diaphram... it has to be the way its supposed to go in.
[Modified by shadowdawn, 3:23 PM 6/11/2002]
For the small effort it would take, why not install the 12:1 disc alone, install it in the car, and see what happens?
Re: Help ASAP with Fmu please (Holden)
Nm I got it setup, I was running a 10 disc which explains my lean condition all these times... after a race with some stupid accord ricer on the freeway (it had viper stripes on it and stickers up the ***) I checked my plugs and all the flaking was gone and the plugs were nice and brownish.... its good to have fuel.
FYI the 12:1 doesn't need a ring, its just the disc and diaphram.
1.8T_EG
05-06-2003 08:06 PM
