FMU discs?
Old Oct 31, 2001 | 05:23 AM
dragnGSR's Avatar
Default FMU discs?
I was wondering where I could get a different FMU disc for the Vortech unit? I am currently running the disc that come with the DRAG kit. I am looking for an 8:1 disc.
Old Oct 31, 2001 | 08:55 AM
sporter's Avatar
New User
Default Re: FMU discs? (dragnGSR)
You can order them directly off the vortech site.
Old Oct 31, 2001 | 12:22 PM
integRated109's Avatar
make sure you get the right one, my 8:1 disk was machined wrong, so i was confused as hell trying to install it. they are sending me a new one though
Old Oct 31, 2001 | 01:08 PM
RGAZ's Avatar
New User
Summit racing also sells the discs. A little cheaper than Vortech and you can get just one and not the whole kit.
If you have the 10:1 disc I will buy it off you when you get the 8:1. I presently have the 12:1 disc. E-mail me.
randygaz@mobilecellular.net
Randy
Old Oct 31, 2001 | 01:37 PM
jbsadler's Avatar
New User
Default Re: FMU discs? (integRated109)
Really???? Did you put your 12:1 back in?
Old Oct 31, 2001 | 02:02 PM
dragnGSR's Avatar
Default Re: FMU discs? (RGAZ)
Sorry, I'm running the 12:1 disc also.
Old Oct 31, 2001 | 03:30 PM
DLB1994's Avatar
will the 10:1 disk run lean on stock injectors
Old Oct 31, 2001 | 04:25 PM
Mikex25's Avatar
New User
Default Re: FMU discs? (DLB1994)
yea it will run lean it is good to use the 10:1 with 310cc injectors. But with the stock stick with the 12:1
Old Oct 31, 2001 | 10:26 PM
dragnGSR's Avatar
Default Re: FMU discs? (Mikex25)
I've got a VAFC, so I figure I can richen up the fuel if need be.
Old Nov 1, 2001 | 03:10 AM
Default Re: FMU discs? (jbsadler)
im lazy, i just dont boost. ill probably do it today if the new 8:1 doesnt show up. im not racing fri. i only have about 270mi on the clutch, and ben said i really should wait the whole 500.
Old Nov 1, 2001 | 04:31 AM
let me clarify, i got some IMs about this. they only make one disk, but mine was machined wrong. a small groove the is suppose to be on the bottom of the adaptor ring, was machined on the top of mine. they are sending me a new one so no prob.
Old Nov 1, 2001 | 05:23 AM
RGAZ's Avatar
New User
WHoa-Whoa-Whoa. No way 10:1 will run lean on stock injectors**. If you use 310cc than you need an 8:1 disc. The 12:1 disc is just overrich and sacrifices power. I don't know why they even give you the damn 12:1, the stock fuel pumps can't get anywhere near the pressure it calls for. This is the deal:
Stock injectors and low boost: 10:1
310cc injectors and low boost: 8:1
High boost: electronic assist of some fashion and 440 or bigger injectors.
(low boost is defined as under 7 psi).
Anyone wanna argue?
Randy
**Disclaimer: of course if you up the compression ratio or don't deal with timing issues then any rate can go lean. I don't expect you to be stupid about this.
Old Nov 1, 2001 | 06:46 AM
i agree about the 10:1, my 12:1 was sooooooo rich.
turbo89civicb18hatch
Apr 5, 2004 10:41 AM
Mucackus
Apr 24, 2002 01:18 PM
uneekcrx
Apr 2, 2002 11:03 PM
