HELP! ARP Problem with Time-sert
Old Dec 16, 2008 | 04:59 PM
T3T4Honda's Avatar
Default HELP! ARP Problem with Time-sert
Ok real quick break down...I bought an ls bottom end for an ls vtec turbo build. The head stud ports were stripped so I had Time-serts installed...So now im building my motor and one of the ARP studs i'm installing gets kinda binded into the block..I backed the ARP head stud out...and it pulled the time-sert out!! Is this normal? It doesnt look like anything holds the time-sert into the block..just threaded in i guess.. I had the time serts done before I had the block hot tanked, so its possible a little bit of rust caused the bind, and when I backed the stud out, it pulled the time sert out with it...So im soaking the arp stud with time sert attached to it in WD-40 right now hoping that it will loosen it up..then I guess I will just thread the whole peice back into the block hoping the time sert will bottom out and then the ARP head stud will continue to thread in until it bottoms out....Sound good?? please any feed back, or any info would help..I dont want to put it all together and have a head gasket blow or something...Thank you for the help.
Old Aug 27, 2012 | 05:41 PM
InTheZoneAC's Avatar
Default Re: HELP! ARP Problem with Time-sert
I know old post, but to those reading this the time sert wasn't seated all the way. It's like they started threading the insert, got snug and backed out.
The driver is supposed to loosen up after the insert is snug and that's when you know it's seated properly.
or this guy is completely getting his stuff wrong and instead is talking about heli-coils, which are bad for head studs.
Old Aug 27, 2012 | 05:53 PM
EsotericImage's Avatar
Retired Moderator
im sure after 4 years he got it
Old Aug 27, 2012 | 06:20 PM
TheShodan's Avatar
Moderator
Can't ever assume that. But I"m glad that this was posted. When my friend and builder went through the process, we went by the instructions to a "T" and worked out well with my sleeved B18C1 block..its now stronger than ever.
Old Aug 27, 2012 | 06:22 PM
wantboost's Avatar
Who is Mr Robot?
some forum members need to be beaten when they bump old *** threads
Old Aug 27, 2012 | 06:39 PM
TheShodan's Avatar
Moderator
Its ok, it was actually informative..
Old Aug 27, 2012 | 06:54 PM
Turbo-LS's Avatar
I used heli coils on my current GSR block with golden eagle studs. Holds stronger than stock threads
Old Aug 27, 2012 | 07:23 PM
Retired Moderator
I researched timesert and helicoils and found everything i needed to know on their site.
i have to install them on my exhaust ports on my P8R head for studs when i do my rebuild.
( o )( o )
Jun 2, 2012 04:13 AM
Raptastik87
Jan 21, 2008 05:35 PM
eth0r
Jul 4, 2006 03:58 PM
TurboCoop
Jul 11, 2005 09:10 PM
baonest1
Oct 17, 2002 06:29 PM
