Help????????
Old Jan 21, 2009 | 08:08 PM
team_lunatics's Avatar
Default Help????????
Hi there...have a 95 integra gsr swap with a h22a turbo. Just took my car to the shop to get it tune. Everything was fine, but then my tuner said vtec will not engage???all vtec wires are correct and in working condition...selonoid is in working condition...dont know what else to think of...need suggestions???car is not throwing any codes off...he said it might be the ecu or the head, but not sure...please anyone with any suggestion will be appreciated??????
Old Jan 22, 2009 | 03:21 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Help????????
i almost locked ot because of the title. more info please.
check the oil level? you need to grab a helms and start chasing the problem.
Old Jan 22, 2009 | 08:01 AM
oil level is good. just wondering what other things might keep vtec from not working???????
Old Jan 22, 2009 | 08:27 AM
srmofo's Avatar
clogged oil passages, low oil pressure, and any number of electrical gremlins
Old Jan 22, 2009 | 05:17 PM
1qwkinline4's Avatar
x2 most common issue is low oil pressure
another issue I've found
? Is the ecu chipped...I've loaded a base map before and came to find out vtec was told in engage and disengage at the same Rpm...check for that or something similar...hopefully tuner would have caught something like that though
Old Jan 22, 2009 | 06:42 PM
thanks everyone with their opionions. well check on that?
Old Jan 23, 2009 | 11:18 AM
bump
seanmaster
Aug 13, 2008 12:48 PM
nelsond
Dec 4, 2006 12:22 PM
mt23vtecbb2
Aug 22, 2003 01:22 PM
01-1293
Oct 9, 2002 03:03 PM
