... heat wrap question...
Old Sep 9, 2003 | 07:32 PM
1.8T_EG's Avatar
Default ... heat wrap question...
... to those who use heat wrap on your downpipe or manifold... how do you secure the heat wrap to the pipes so that it does not unravel, come off, or come loose?... lemme know... thanks...
Old Sep 9, 2003 | 07:33 PM
racerxadam's Avatar
Default Re: ... heat wrap question... (1.8T_EG)
hose clamps, or they make special ties just for heat wrap. its a metal band that uses a little clip to hold it in place. look on summitracing.com or jegs.com
Old Sep 9, 2003 | 07:34 PM
racerxadam's Avatar
Default Re: ... heat wrap question... (racerxadam)
http://www.jegs.com/cgi-bin/nc...r=361
Old Sep 9, 2003 | 09:07 PM
inspyral's Avatar
hose clamps - cheap and effective
My dp before I sold it:
I started at the turbine flange and used one clamp there, and used 2 down by the flex.
Old Sep 9, 2003 | 09:15 PM
t616
Guest
Posts: n/a
Default Re: (inspyral)
curious as what to and what not to heat wrap ?
Old Sep 9, 2003 | 09:37 PM
tegasaurus's Avatar
Default Re: (aesop-)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aesop- &raquo;</TD></TR><TR><TD CLASS="quote">curious as what to and what not to heat wrap ? </TD></TR></TABLE>
my thoughts exactly... i know that it keeps heat in which would increase energy within a pipe, so it would be logical to do the manifold, however wouldn't more heat make it more prone to crack?
-ryan
Old Sep 9, 2003 | 10:13 PM
accordfreak's Avatar
Default Re: (tegasaurus)
are you supposed to spray the heat wrap with something before you put it on? all the pos fiberglass particles fly EVERYWHERE
Old Sep 9, 2003 | 10:17 PM
Drew Peacock's Avatar
Default Re: (accordfreak)
Just wrap it up and bake it on slowly, once finished. it smells like hokey pokey cooking. Nah it shouldn't cause your mani to crack unless your mani is crap to begin with and in that case in just a matter of time anyway.
Old Sep 9, 2003 | 10:19 PM
Kack's Avatar
Default Re: (turbozxi)
can u get heat wrap at the local muffler shop? If not...where?
Old Sep 9, 2003 | 10:23 PM
Default Re: (Kack)
Local performance shop dirty V8 shops have it to.
Old Sep 9, 2003 | 10:24 PM
MikeMAN's Avatar
i used hose clamps on my last setup...worked GREAT!
mike
Old Sep 9, 2003 | 11:40 PM
lazerus's Avatar
Default Re: ... heat wrap question... (MikeMAN)
only bad thing is when your wrapped downpipe rubs against the road...
not good. heh
Old Sep 9, 2003 | 11:58 PM
Full-Race Javier's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accordfreak &raquo;</TD></TR><TR><TD CLASS="quote">are you supposed to spray the heat wrap with something before you put it on? all the pos fiberglass particles fly EVERYWHERE</TD></TR></TABLE>
dipping the wrap in water works ok
Old Sep 10, 2003 | 12:14 AM
rjardy's Avatar
Default Re: (javierb14)
Aircraft grade safety wire and safety wire plyers work great. I figure if its good enough for aircraft its good enough for me. I have tons of it lying around, my dad was a jet engine mechanic in the Airforce along time ago, and he "acquired" a few hundred spool of this stuff.
Rob
edit: spelling
Old Sep 10, 2003 | 02:09 AM
KTeller8's Avatar
Default Re: (rjardy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rjardy &raquo;</TD></TR><TR><TD CLASS="quote">Aircraft grade safety wire and safety wire plyers work great. I figure if its good enough for aircraft its good enough for me. I have tons of it lying around, my dad was a jet engine mechanic in the Airforce along time ago, and he "acquired" a few hundred spool of this stuff.
Rob
edit: spelling </TD></TR></TABLE>
obuhmyuh
Feb 25, 2008 04:54 PM
D15Bbigred
Apr 7, 2007 09:42 AM
11secteg
Apr 4, 2007 06:12 PM
juicedse
Welding / Fabrication
Oct 15, 2004 01:28 PM
Boost Addict
May 8, 2004 04:30 PM
