Headgasket woes....gimme some help, guys!
Anyway...I blew my headgasket today....wanna replace as soon as possible. Gimme some recommendations if at all possible. I just need something for street use...nothin to fancy. Thanks guys!
Re: Headgasket woes....gimme some help, guys! (ekb18c)
Is it pretty simple to do? Anything I should watch out for? I'm only a novice mechanic.
Re: Headgasket woes....gimme some help, guys! (95civicturbo)
Take it slow. I would buy new headbolts. You need a breaker bar or cheater for removing the headbolts. A pan for holding spilled coolant. Put the motor at TDC.
Get a manual. Be sure you have a back up car in case you cant do it. Its not so bad.
After I worked on a H22 I never knew what I was missing when doing a head gasket. Vtec are much easier than non-vtec.
Re: Headgasket woes....gimme some help, guys! (Doodoo)
Make sure you pull all the sensors and coolant lines off the head before you try to pull the head. You can loosen the timing belt tensioner to give you enought slack to slide the belt off and back on. Make sure everything is at TDC when you put it back on. Oh yah, the intake manifold has this lame bracket that braces it to the block, make sure you get that out of the way too. You'll want to pull both manifolds to make it easier to get the head off. Use new gaskets for anything you take off. The head bolts need to be torqued in a specific sequence in a couple stages. Now would be a good time to pick up a Helm's if you don't already have one.
torque them in sequence like inspyral said clean the mating surfaces and lube the bolts before installing them.
Re: Headgasket woes....gimme some help, guys! (drealboostedhybrid)
what do you guys use to clean surfaces, and to keep stuff fom getting in the water jacket/oil holes and all that??
Re: Headgasket woes....gimme some help, guys! (BoOsTeD_eK)
Get new head bolts and go back with a stock gasket. Can't go wrong, I've seen 20+psi on them time after time.
Re: Headgasket woes....gimme some help, guys! (Jared)
Ok...maybe I didn't blow my headgasket. No antifreeze in my oil or visa versa...everything is acting normal now....WTF? No antifreeze bubblin or nothin...any other tell-tale signs of headgasket problems?
Blow by gases, eh? How do I do that? I will check as soon as you tell me how!
Re: Headgasket woes....gimme some help, guys! (inspyral)
So...just out of curiousity...how bad is it to blow an acura headgasket? I've heard that its really not that big of a deal and actually not harmful to your motor to continue to drive it. How accurate is this? I know I sure as hell wouldn't have driven my Z28 with a blown headgasket!
