head gasket replacement?
was wonder if anyone knows where i could find instructions on how to replace a head gasket on a 1993 civic dx hatchback, motor is d15b7. im sure any civic head gasket replacement would be similar. lmk thanks.....i did a search and couldnt find, maybe didnt search hard enough, but if you guys can help, that would be great. thank you.
This is not an easy task.
You should buy a manual for the car, like a Chiltons or Haynes.
You need to remove the timing belt from the cam gear.
Removing the Dizzy helps in removing the heater hose under it.
Tip for the timing belt. Set the engine up on TDC. To lossen the timing belt tensioner use 14mm socket and back the bolt out of the plastic cover until the bottom of the head is just below the plastic cover. Don't pull the bolt all the way out.
You'll want to have the head checked for flatness by a shop.
I hope you have a good set of tools and lots of time.
I done this job many times and it's not fun.
You should try: http://www.turboD16.com We have lots of post about HG's there.
Re: (1992Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1992Si »</TD></TR><TR><TD CLASS="quote">I done this job many times and it's not fun.</TD></TR></TABLE>
It gets easier as you do it. A friend and I can get a b18 head off and on in about 30mins. Running in an extra 10. This is with hand tools too.
95civicdb
03-25-2010 05:57 AM
