Headgasket question
Old May 3, 2005 | 12:03 PM
Si Shane's Avatar
Default Headgasket question
81.5 mm bore. I should use an 82mm headgasket right?
Old May 3, 2005 | 12:04 PM
s2kdre's Avatar
Default Re: Headgasket question (Si Shane)
oem is good enough.
Old May 3, 2005 | 12:14 PM
Si Shane's Avatar
Default Re: Headgasket question (jdmhonda)
i ordered an 82, and i just got an 81. Should i send it back for an 82 or just keep it?
Old May 3, 2005 | 12:30 PM
Si Shane's Avatar
And when you order headstuds for an b18a1+b16a2 ls vtec you get headstuds for the b16, right?
And is there any markin on Eagle rods to denote the 3/8" rod bolts? Thats measuring the threaded part correct? The head of my bolts are ~3/8" but the bolt itself is only 1/4"
Modified by Si Shane at 1:44 PM 5/3/2005
Old May 3, 2005 | 12:43 PM
Si Shane's Avatar
Here:
Old May 3, 2005 | 02:21 PM
vangc6780's Avatar
i have the same question about three months ago....
i've got the answer your stock 81mm should be good enough thats what i used on my 81.5mm.....
hope that helps
Old May 3, 2005 | 04:19 PM
SPOOLINmatt's Avatar
Default Re: Headgasket question (vangc6780)
yeah and for head studs, i think its GSR, AEBS actually makes a set for the ls vtec setup that im gonna get.
Old May 4, 2005 | 10:09 PM
dthrone's Avatar
Default Re: Headgasket question (SP00LIN)
I run a stock sized cometic head gasket
Old May 5, 2005 | 08:10 AM
earl's Avatar
Default Re: Headgasket question ("SPANKY")
If you have an 82mm bore, do not use an 81mm gasket. You do not want the gasket hanging over the bore.
An OEM gasket can be used on an 81.5mm bore as it is slightly larger than 81mm in diameter.
C_Rock77
10
Mar 24, 2010 10:15 AM
aser1z
May 12, 2005 08:13 PM
jdmlsvtecrx
Apr 5, 2005 01:36 PM
prada_2o0o
Aug 5, 2003 09:49 AM
prada_2o0o
Jul 24, 2003 09:40 AM
