headgasket help please.
Old Mar 28, 2011 | 05:07 PM
mangina's Avatar
Default headgasket help please.
like a idiot, i torqued my headgasket while it was backwards.
i noticed it and put it the right way. torqued my arp's to 80ftlbs
now i have a small leak from the headgasket below the vtec soleniod.
is it possible that i damaged the headgasket by torquing the gasket upside down?
or should the gasket be ok to use once its the right way?
thanks.
Old Mar 28, 2011 | 05:31 PM
pcguy760's Avatar
Default Re: headgasket help please.
I would replace it since you do have a leak from the one side of the actual headgasket (as you say) - that could possibly get worse over time and cause even worse problems. Thats just my 2c when it comes to critical components like that
Old Mar 28, 2011 | 05:43 PM
bigsnorlax's Avatar
If its leaking.. then yes you must replace it. If you have it turned the right way and re-torqued it and noticed the leak... then there really is no other option.. unless you want to wait for it to get worse and have to do it again anyway...........................
Old Mar 28, 2011 | 06:00 PM
Mr. EG's Avatar
I would replace it, don't cheap out.
Old Mar 28, 2011 | 06:10 PM
mangina's Avatar
its not about being cheap. just wondering if torquing it upside down would damage it.
damn! new HG it is!
thanks
user1122
Jun 11, 2015 04:44 AM
JDMDAtehbeast
Dec 9, 2009 05:23 PM
5.56
Jan 13, 2009 02:14 AM
EKIM NART
Nov 19, 2007 08:43 AM
my4drGSR909
Mar 26, 2005 10:01 PM
