Headgasket Help!!!
Old Jan 31, 2005 | 07:30 AM
bluesi00's Avatar
Default Headgasket Help!!!
Im sorry for asking stupid questions, but my friend is on his second hg install in just 3 months. he wanted me to ask if theres a certain way to put in a hg. he has a sleeved b16 with a 84 mm bore and turbo. he blew a cometic hg and now a ge. is he supposed to take off the dowels? or does he just take off the head and put the hg on exactly how he bought it from ge? he already got the block and head decked/milled. any input will be helpful. thanks
Old Jan 31, 2005 | 07:41 AM
b18bturbo's Avatar
Default Re: Headgasket Help!!! (bluesi00)
if you ahving sealing issues what you need to examine is the deck and head mating surfaces. There is only one way to put th gasket on correctly.
Also on the dowel pins did you shave them down according to how much you milled from the head and block.
Old Jan 31, 2005 | 07:42 AM
X-Mazda 3 Racer's Avatar
What head fasteners is he using? What lube and what torque is he setting them at? Make sure the dowel pins are not too long. This happens often especially on milled heads and blocks. This can cause the head to sit up a bit and will cause the gasket to blow. Also, make sure everything is spotless, completely clean before install. I use copper srpay on all my gaskets as well.
Old Jan 31, 2005 | 09:42 AM
bluesi00's Avatar
he uses arp headstuds and he didnt grind the dowels down. how do u know how much to grind down??
Old Jan 31, 2005 | 10:18 AM
Default Re: (bluesi00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluesi00 &raquo;</TD></TR><TR><TD CLASS="quote">he uses arp headstuds and he didnt grind the dowels down. how do u know how much to grind down?? </TD></TR></TABLE>
You have to measure, or you can take a guesstimate Cut about .100: off the dowel. That will be sure to clear.
Old Jan 31, 2005 | 10:47 AM
bluesi00's Avatar
ok thanks!! by the way. u sell ge stock overbore hg's for a b16a2 right?? i think i bought my other hg of u guys.
Old Jan 31, 2005 | 10:51 AM
DaX's Avatar
DaX
Loved
Community Favorite
EEK! I didn't have my dowels modified and I just did a HG. The head only had 0.003" taken off...do you think it will be ok? [sorry to thread jack]
Yes, GE sells OEM overbored HG's.
Old Jan 31, 2005 | 10:52 AM
bluesi00's Avatar
haha, its cool.
Old Jan 31, 2005 | 10:54 AM
Some times if the block or head was deck a bunch, the dowels will sit up. I run into this problem customers a few times a year. .003" should be o.k., but anything more should be checked Yes, we sell OEM overbored gaskets, almost any bore size you need.
MigsD16
Engine Machining & Assembly
Dec 17, 2016 05:17 PM
JDMpadawan
Mar 18, 2014 12:27 PM
strike1545
May 24, 2010 10:42 AM
integraturbo
Oct 29, 2008 10:56 AM
I8ayellowcrayon
18
Jan 29, 2004 11:42 AM
