headgasket bore size question
Old May 23, 2004 | 09:35 AM
M.A.R.C.'s Avatar
Default headgasket bore size question
just a quick question for engine builders out there...
I called up Cometic this past week and I was asking about a 77mm d16 headgasket (the bore of the motor is 77mm). Jason from Cometic recommended I go with a 78mm bore gasket. That kinda seems odd to me because I thought the gasket bore size had to match the block bore size. The reason I'm inquiring is because I've ordered a 77mm d16 hg from 2 months ago and still hasn't gotten here. I am carless and I need to get it running ASAP and I'm sure during calling around I heard at least one person say they have a 78mm gasket IN STOCK which would be good if I can run that. So the question again is... is it SAFE to run a 78mm bore gasket on a 77mm bore motor? just more background it's a 77mm GE sleeved D16Z6 block with a Y8 head. The motor will be seeing high boost soon so that's important.
Thanks in advance.
Marc
Old May 23, 2004 | 01:54 PM
M.A.R.C.'s Avatar
Default Re: headgasket bore size question (CivicRyda2k)
updog
Old May 23, 2004 | 01:55 PM
G
sh!t happens.
bump for good question
Old May 23, 2004 | 02:21 PM
M.A.R.C.'s Avatar
yah thanks i wanna know by tomorrow... need to gets meh car running!
Old May 23, 2004 | 05:01 PM
M.A.R.C.'s Avatar
up for the nite crew
Old May 24, 2004 | 02:35 AM
M.A.R.C.'s Avatar
BUMP
Old May 24, 2004 | 07:56 AM
earl's Avatar
The 78 would probably work ok but a 77 or even 77.5 would be better. The more area you get BETWEEN the cylinders with your gasket, the better off you are.
Old May 24, 2004 | 03:23 PM
M.A.R.C.'s Avatar
Default Re: headgasket bore size question (earl)
thanks Earl. thanks to Marcos @ Murray's i found a 78mm gasket locally. car should be running by this weekend!
B Dap
Apr 4, 2010 08:25 AM
reyesb25
Jan 21, 2009 08:07 AM
92HB_HB
Mar 18, 2005 05:25 AM
