Headgasket
Old Oct 30, 2001 | 12:58 PM
Stunna BEN's Avatar
Don't call it a comeback
Default Headgasket
Anyone in here using the Inlinepro headgasket? What are the pros and cons of it? If anyone is using it what is the highest boost levels you have ran or can run safely with one on a stock b18c1? Any other information would be highly appreciated!
Old Oct 30, 2001 | 03:18 PM
Stunna BEN's Avatar
Default Re: Headgasket (Big Carbon)
No one huh?
Old Oct 30, 2001 | 03:22 PM
liam821's Avatar
25 Year Member
There is one guy on here running an inline pro. Their website says you can run up to 22psi with a 100% internally stock b18c1 motor and good fuel management. Which i can believe.
He has that same setup and has run mid 11's i believe...although i dont remember off hand.
I believe it lowers the compression to around 9:1. It will hurt low end power but you can run more boost.
liam
Old Oct 30, 2001 | 03:30 PM
Stunna BEN's Avatar
Default Re: Headgasket (liam821)
Good lord. 22psi. How think is it? What is their web site? Seems very impressive though. Thanx again for the info...
Old Oct 30, 2001 | 03:35 PM
liam821's Avatar
25 Year Member
Their website is...
http://www.inlinepro.com/
click on showroom then headgaskets
I am not sure how thick it is..but i would imagine it is around 3-4mm thick.
liam
Old Oct 30, 2001 | 04:25 PM
FAST94GSR's Avatar
New User
THE HT GUY NAME IS JINXPROOF OR JINXPROOF99. he runs low 11's in a stock b18c with 20-22lbs of boost,that's in a 92-95 hatch.
theLame1
Jun 4, 2013 03:15 PM
GoldLudeRay
Dec 31, 2011 04:29 PM
THE ONE
Aug 26, 2004 07:25 AM
the jdmchop
Feb 29, 2004 01:48 PM
PM-Performance
Feb 26, 2003 09:26 AM
