Head set up for B-series forced induction?
Old Mar 6, 2004 | 03:44 PM
B17aTrbo's Avatar
New User
Default Head set up for B-series forced induction?
Looking to do the head on my b series motor.
No flames please because I put "head" in the FI archives search and didn't see much of anything, if there is something better or a link to a good thread on this please point me in the right direction!
I'd like to set it up to run between 9k and 9500 rpms to take advantage of my turbo's powerband.
I'm looking at the SuperTech valvetrain valves springs and retainers (dished, factory sized valves) I know they will be strong enough for my setup...also had considered the REV's.
Who does the good headwork? Do I even need headwork or just the valvetrain? I do not plan on trying to do any head porting myself, so who is good to send it to?
If any additional info is needed to help me out please let me know...
450whp, T3 sc61 76trim .63 A/R
84mm bore
Modified by B17aTrbo at 9:18 PM 3/6/2004
Modified by B17aTrbo at 9:20 PM 3/6/2004
Old Mar 6, 2004 | 05:11 PM
HEAD's Avatar
Default Re: Head set up for B-series forced induction? (B17aTrbo)
what size turbo? and how much power do you want to make? Bore size?
Old Mar 6, 2004 | 05:21 PM
RenoRacing's Avatar
Default Re: Head set up for B-series forced induction? (HEAD)
lol. i just thought it was really funny how "head" replied first. lol
Old Mar 6, 2004 | 05:22 PM
B17aTrbo's Avatar
New User
DoH! Forgot to put the hp and turbo...I put the bore size too.
Old Mar 6, 2004 | 06:22 PM
DLB1994's Avatar
stock valves will easy hold 450whp,what cams are you going to run?
really all you need is valve springs and retainers to rev that high, i would look in to R or gsr cams
ill like to see what kinda tq you make hopefully you make at least 350wtq
Old Mar 6, 2004 | 06:47 PM
b18cya94's Avatar
Default Re: Head set up for B-series forced induction? (DLB1994)
i make 500whp with rev valvesprings, retainers, and valves, with gsr cams and i shift it at 8800
Old Mar 6, 2004 | 07:07 PM
B17aTrbo's Avatar
New User
It's the factory b17 cams...I don't know the specs on the b17 cams tho...does anyone?
Old Mar 6, 2004 | 07:21 PM
b18cya94's Avatar
i think the b17 and b16 cams are the same the gsr are a little different.
Old Mar 8, 2004 | 10:36 AM
B17aTrbo's Avatar
New User
Default Re: Head set up for B-series forced induction? (b18cya94)
I am going to just leave the head alone and upgrade the valvetrain...
That should be good for me.
asubennett
Feb 19, 2005 09:03 PM
ScottEK
Dec 3, 2004 12:55 PM
SoCaLNaTIvE
Dec 27, 2003 11:46 PM
Speed PHreak
Mar 1, 2002 04:40 PM
