bigger head studs?
Old Jan 4, 2003 | 10:50 PM
paulzy's Avatar
Default bigger head studs?
I remember Vince(GEM)saying something tha tthe ARP head studs can only hold so much pressure before they start to let the head lift. He also said that Most Pro guys are now upgrading to a larger(fatter)head stud combo. Does anybody have any info on them? Where can I get these head studs? Is all that is needed is to enlarge the holes in the block/head and retap threads?
Old Jan 4, 2003 | 11:17 PM
earl's Avatar
Default Re: bigger head studs? (1320development)
You want to use the Ford 302 studs. I believe they are 1/2" diameter. There is enough meat in the block to retap but it must be done on a mill. Talk to ARP and they will match you up with the proper length. The head holes will have to be enlarged slightly (also with precision)
Old Jan 4, 2003 | 11:30 PM
BlueShadow's Avatar
How much HP/PSI are the ARP studs good for? and I thought that 1/2" studs was like a big secret that shouldn't be talked about openly J/K
thanks
Old Jan 4, 2003 | 11:34 PM
TurboITR's Avatar
just get a set of the aebs studs
Old Jan 5, 2003 | 12:01 AM
tony1's Avatar
Default Re: bigger head studs? (TurboITR)
We still run stock sized studs...
Old Jan 5, 2003 | 12:19 AM
ninesecrx's Avatar
Default Re: bigger head studs? (tony1)
some will say that if you lifting a head with stock arp's, you got something else wrong. People can tell you all the secrets in the world, doesnt mean it will help you any.
Tong.Y
Jan 17, 2011 03:26 PM
PhrequenC
Jun 9, 2008 10:55 AM
n0pinitr0us
Aug 19, 2005 12:04 PM
9seccivicsi
Sep 20, 2004 10:55 AM
baonest1
Oct 17, 2002 06:29 PM
