head gaskets
Old Mar 28, 2005 | 11:38 AM
vangc6780's Avatar
Default head gaskets
will a stock honda head gaskets be good enough for boost aroound 10.5lbs-17lbs???
Old Mar 28, 2005 | 11:42 AM
tgreaves's Avatar
Default Re: head gaskets (vangc6780)
Depends if your block surface and head surface are flat..
Old Mar 28, 2005 | 11:47 AM
Benjithx's Avatar
cometic is a good gasket but their customer sucks
Evanmb44's Avatar
Default Re: head gaskets (Benjithx)
i would upgrade.
why risk it??? good insurance this way
Old Mar 28, 2005 | 12:02 PM
dennis's Avatar
If the stock gasket will fit your bore and like someone else said, both head and deck are clean/flat (which is 100 times more insurance than just using a different gasket), it will be fine.
I wouldn't upgrade unless I was running a different bore or thickness than what OEM could sufficiently provide.
Old Mar 28, 2005 | 12:05 PM
Cray91's Avatar
Just go with OEM and some copper spray.
The surfaces being flat is more important than anything. Bring your stuff into a machine shop.
Old Mar 28, 2005 | 02:50 PM
vangc6780's Avatar
Default Re: (Cray91)
do you mean both the block and the head or just the head???
Old Mar 28, 2005 | 03:58 PM
kabaroo's Avatar
Default Re: (vangc6780)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vangc6780 &raquo;</TD></TR><TR><TD CLASS="quote">do you mean both the block and the head or just the head???</TD></TR></TABLE>
Block and head
Old Mar 28, 2005 | 05:01 PM
PrecisionH23a's Avatar
OEM is all you need unless you are looking to lower/increase your compression.
Old Mar 28, 2005 | 05:44 PM
redzcstandardhatch's Avatar
something different
i'd stick with OEM.
MigsD16
Engine Machining & Assembly
Dec 17, 2016 05:17 PM
turbodailydan
Jul 19, 2009 07:54 PM
-Darren-
Jun 2, 2009 03:54 PM
integraturbo
Oct 29, 2008 10:56 AM
