head gasket?
Old Aug 4, 2006 | 02:10 PM
evade this honda's Avatar
Default head gasket?
I have ctr pistons in a b16 but want to turbo it. what head gasket would be good to use? not sure in size. I know i need one that will lower the compression and I already have the head studs.
Old Aug 4, 2006 | 02:25 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: head gasket? (evade this honda)
they say a 2mm for a usdm, and a 3mm for a jdm b16. i think youll be ok with a 3mm.
int he past we have used a 2mm on 99-00 si's setup for boost on stock internals.
please correct me if i am wrong.
Old Aug 5, 2006 | 06:53 PM
who sells a 3mm head gasket
Old Aug 5, 2006 | 07:51 PM
TypeSLO's Avatar
Default Re: (evade this honda)
cometic
Old Aug 5, 2006 | 08:43 PM
KeyserSoze's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by evade this honda &raquo;</TD></TR><TR><TD CLASS="quote">who sells a 3mm head gasket</TD></TR></TABLE>
I believe they have a .074" headgasket, that is supposed to lower the cr by 1 pt. GL.
Old Aug 5, 2006 | 10:01 PM
problem is my cr is 11:1 so i need to go to at least 9:1
Old Aug 5, 2006 | 10:02 PM
Mr. Badwrench
you arent gonna get that with a headgasket.
let your tuner know what your static compression is, and go a little conservative on it. your compression is a little higher, so keep the boost a little lower.
Old Aug 6, 2006 | 06:39 AM
Im lookin to boost about 10psi or 8psi depends on what he says durin the tune
Old Aug 6, 2006 | 09:04 AM
EGNA's Avatar
if compression that high i wouldnt push it..
Old Aug 6, 2006 | 09:28 AM
TypeSLO's Avatar
Default Re: (EGNA)
high compression + boost + good tune = sick power!
Old Aug 8, 2006 | 09:36 PM
KeyserSoze's Avatar
Default Re: (boostedcivicsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir &raquo;</TD></TR><TR><TD CLASS="quote">you arent gonna get that with a headgasket.</TD></TR></TABLE>
Negative. Cometic makes headgaskets as thick as .120." That would technically be a cr drop of over 2 (more like 2.25). Now whether or not this would be the best way to do it is definately debatable, but it can be done.
Old Aug 12, 2006 | 10:16 PM
I contacted inline pro and they have a gasket that is 3mm and that my friends makes my cr go 9:1
Old Aug 12, 2006 | 10:48 PM
qfast817's Avatar
well if its a good tuner you dont have to lower the compression that low
Old Aug 13, 2006 | 07:32 AM
i dont want to take the chance with my cr being 11:1. I would rather just lower it to 9:1 and be able to run more boost
EF88Vtec
Oct 12, 2008 09:06 PM
raphael
Feb 16, 2007 10:21 AM
silentdaredevil2
Nov 24, 2005 12:29 PM
rmcdaniels
Nov 23, 2005 11:45 AM
p1ccoloz
Apr 21, 2003 09:41 AM
