Is this head fixable?!?
Old Jun 1, 2007 | 08:33 PM
AaronJ's Avatar
Default Is this head fixable?!?
So i just went to install a b18b bottom end with my b16 head...Everything went ok, but the car only ran for about 2 minutes. I pull the cams to find this
This is the cam journal closest to the t-belt
2nd one closest to the tbelt
Cam itself
Cam cap
One more
I think i may have had my timing belt to tight, because the journals closest to the dizzy are fine, and they get worse closer to the tbelt. I don't know if this is fixable, or if the cam is any good any more
Old Jun 1, 2007 | 08:35 PM
Ubertec's Avatar
Default Re: Is this head fixable?!? (AaronJ)
Looks like its pretty well jacked
Old Jun 1, 2007 | 08:40 PM
zexxbo's Avatar
Default Re: Is this head fixable?!? (Ubertec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AaronJ &raquo;</TD></TR><TR><TD CLASS="quote">Everything went ok, but the car only ran for about 2 minutes.</TD></TR></TABLE>
lol
did you have any oil in your head? see what your shop says, looks pretty well scarred tho- id say the cams are done for sure..
Old Jun 2, 2007 | 01:41 AM
SD_Lurker's Avatar
HT White Ops
Default Re: Is this head fixable?!? (zeimbo)
If the grooves are not super deep, which they don't look to be, I think it can be fixed. I know Dave at headgames has fixed some like that but I don't know the extent of the damage.
Did you even use any assembly lube when you reinstalled those cams?
Old Jun 2, 2007 | 06:23 AM
Muckman's Avatar
Moderator in Chief
That head had no oil.
Old Jun 2, 2007 | 06:46 AM
Turbocivic94's Avatar
Default Re: Is this head fixable?!? (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">That head had no oil.</TD></TR></TABLE>
Old Jun 2, 2007 | 08:15 AM
Mr HYDE's Avatar
Default Re: Is this head fixable?!? (Turbocivic94)
you can have that belt super tight and it wont do that. that head def didnt have enough oil and you ran the journals dry
Old Jun 2, 2007 | 09:16 AM
THEDirtyDseriesWOOT's Avatar
assembly lube is your Friend
Old Jun 2, 2007 | 09:28 AM
BlueSi2k's Avatar
Default Re: (THEDirtyDseriesWOOT)
I don't think assembly lube would have saved that, you have a problem elsewhere. I usually don't use assembly lube when putting the cams in just make sure to put a lot of oil on everything.
Old Jun 2, 2007 | 09:44 AM
AaronJ's Avatar
Default Re: (BlueSi2k)
Yeah i didn't have any assembly lube, so i just put oil all over everything...I also fulled the ECU fuse and primed the engine to get oil pressure before i started it. I am supplying oil to the head via a filter sandwich and a line to the back of the head.
Old Jun 2, 2007 | 10:51 AM
EARLdaSQUIRREL's Avatar
official honda whore
Default Re: (AaronJ)
you sure you had the cam caps in the right places and everything was clean
i had an itr head like that and sold it for cheap because i coulldnt get it fixed
Old Jun 2, 2007 | 11:13 AM
TcUiRvBiOc's Avatar
Default Re: (coptzer)
i had the same thing happen to one of my heads a couple years ago, when i took the head off my ls vtec to put it on a gsr block i got. i had to drill the oil hole back out that was blocked for the ls motor but i obviously didnt get all the metal shavings out and they chewed up the head and cam pretty bad just like that.. so id say u had some dirt or metal shavings that worked there way in there and ate it up or blocked the oil passage.. u wanna make sure everything is very clean of dirt or anything that would clog the oil passage...
Old Jun 2, 2007 | 03:06 PM
the.hamburglar's Avatar
Default Re: (TcUiRvBiOc)
did put the caps for the cams on too tight?
Old Jun 2, 2007 | 06:54 PM
Muckman's Avatar
Moderator in Chief
Hey dumb question - do you have a "LS/VTEC" oil feed for the head?
Old Jun 2, 2007 | 08:20 PM
KeyserSoze's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">Hey dumb question - do you have a "LS/VTEC" oil feed for the head?</TD></TR></TABLE>
Another dumb one, what timing belt did you use??
Old Jun 4, 2007 | 06:08 PM
HEAD's Avatar
all I can say is....wow! Jesus couldn't fix that..and he has help from above.
Old Jun 4, 2007 | 06:30 PM
B18C1CYA's Avatar
no oil , what way where the numbers facing when you put the caps back on ???
Old Jun 21, 2007 | 04:29 PM
Heretic:Si's Avatar
Default Re: Is this head fixable?!? (Mr HYDE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr HYDE &raquo;</TD></TR><TR><TD CLASS="quote">you can have that belt super tight and it wont do that.</TD></TR></TABLE>
chrisc543
Engine Machining & Assembly
Apr 13, 2016 06:57 PM
Nigel379
Jul 16, 2007 01:45 PM
rough_draft
Mar 26, 2005 05:32 PM
blykins
70
Nov 22, 2004 07:34 AM
92redgsr
Oct 23, 2003 06:24 PM
