head bolts
Old Nov 27, 2001 | 08:24 PM
PROFILES2000's Avatar
Default head bolts
ok i did a search couldnt find anything ........heres the story im rebuilding my motor with je pistons and eagle rods i am going to have this thing torn apart are ARP or other brand head bolts a good investment, where can i find info such as prices and specs. i have a b16 head on a gsr bottom if it makes a difference
Old Nov 27, 2001 | 08:28 PM
Liltrix's Avatar
Default Re: head bolts (PROFILE GSR)
http://www.fasttrackmotor.com
Old Nov 27, 2001 | 08:58 PM
Default Re: head bolts (Liltrix)
where on that page should i look i checked out most of it and couldnt find anything there
Old Nov 27, 2001 | 09:18 PM
ekb18c's Avatar
Dude just get ARP Head studs. They run around 175 for all the studs.
Old Nov 27, 2001 | 09:28 PM
Default Re: head bolts (ekb18c)
thanks that what i was looking for
now how about some info on why i should get them and not either stick with stock or get a differnt brand
Old Nov 27, 2001 | 09:33 PM
Arturbo's Avatar
Better than steak
25 Year Member
I just ordered some ARP head studs from $112 from Summit racing.
art
Old Nov 27, 2001 | 09:52 PM
Adi Radoncic's Avatar
On Fire!
Default Re: head bolts (Arturbo)
art
I second that, and you can never beat the free ground shipping!!
Old Nov 27, 2001 | 09:54 PM
Default Re: head bolts (newgsr)
ok i didnt even have to do the shopping thanks guys...u can always count on a fellow honda-tech member to help you out in those clutch situations! ordering tomarrow after i get outta class
Old Nov 27, 2001 | 10:19 PM
Blown90hatcH's Avatar
Make sure you get them for a GSR....not a B16a.
Old Nov 27, 2001 | 10:34 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: head bolts (Blown90hatcH)
If Im not mistaken, I dont think they make them for a b16a. I may be wrong tho.
art
Old Nov 27, 2001 | 10:39 PM
Either way...B18 block and B16 head = B18 head studs...
Old Nov 27, 2001 | 10:43 PM
bigTom's Avatar
they are the same... the differance between honda studs is mostly the length of them
Old Nov 27, 2001 | 10:48 PM
Default Re: head bolts (ek9t)
Yeah...Exactly...B16a head studs are shorter than the B18c studs
Old Nov 27, 2001 | 10:50 PM
On Fire!
Profile Gsr: Ummmm this is just in case you didn't know but the Head stud kits have 12-point nuts so a right socket is another thing to worry about if you are doing the work yourself.
Old Nov 27, 2001 | 10:54 PM
Arturbo's Avatar
Better than steak
25 Year Member
ahhhh ok, I didnt read he had a b18 with b16 head. so on me. Thats what I get for not reading the entire post. Im my world, I only think of B18c things..
art
Old Nov 28, 2001 | 05:24 AM
ok i was just about to order them as we speak but i deceided to see if anyoen else had posted something.....would gsr studs fit? i am having a close friend do the work for me i know hes taken off my flywheel before and those have 12 points on them soo......more over which studs should i order
Old Nov 28, 2001 | 06:20 AM
93B17A's Avatar
how about for a B17 ? do they have head studs for have motor?
Old Nov 28, 2001 | 08:05 AM
Just get some ARP head studs from Summitt for a GSR. You need the GSR studs, cause they are longer than the B16 ones. Yes, the ARP studs are a 12pt head.
Old Nov 28, 2001 | 09:36 AM
boosted3g's Avatar
Also make sure you get the 1/2 inch drive 13mm with a deep socket for them. The walls are a little thicker than the 3/8 and you will need a deep socket to reach them. I have broke a few sockets on tightening the head bolts. Thank god for craftsman, I severly abuse the broken tool policy at Sears.
Old Nov 28, 2001 | 07:38 PM
turbotypeR@SPEC's Avatar
25 Year Member
from the experiences i have had,i think the stock ones are just as good.i have accidentally boosted around 50lbs of boost with no head gasket problem on stock bolts.now,i have arp studs and am experiencing problems at 17 lbs(no,it is not running lean). i am thinking that the honda ones may even be better.i called arp and ask if he thought the studs could have stretched,and he said "anything is possible".
Old Nov 29, 2001 | 11:20 AM
Incognito's Avatar
Default Re: head bolts (turbotypeR)
Are stock B16A head bolts shorter than stock GSR head bolts? What about ITR ones? I am asking because when I slapped my B18C5 back together (ITR head and ITR block), I used head bolts from a '00 Si. It's a naturally aspirated car.
Old Nov 29, 2001 | 11:35 AM
sgT's Avatar
sgT
Default Re: head bolts (Incognito)
B17A, B17A, B18C all use same head bolts/studs. Same length.
Its the head that makes the bolts require different lengths. Hence the reason
why b18a/b need different length bolts.
Old Nov 29, 2001 | 12:07 PM
Liltrix's Avatar
Call Wayne 718-968-9113
Old Nov 29, 2001 | 01:22 PM
93B17A's Avatar
Default Re: head bolts (sgT)
thanx sgT cause i want to order those bad boys........ cause i have almost everything else for my turbo re-build and the head bolts were the only thing i had troulbe with
turbocivic1984
Jun 4, 2008 01:28 PM
YingYangh22a1
May 13, 2008 10:24 PM
DJaeMac
Honda Civic (2001 - 2005)
May 7, 2007 04:00 AM
IntegraMark
Feb 28, 2007 06:12 AM
h22squeaker
Apr 4, 2005 08:20 AM
