having cooling problems
ever since i put my turbo on in my 89 civic 4dr i've been running on the really warm side. you think if i run thermal wrap on my DP would keep my temp down
Yea it may but not drastically. Does it over heat? How much of the overheat gauge is reading?
Turbo motors are known to be a little more on the hotside. Also are you using a stock radiator, if so swap that out and get a fluidyne.
[Modified by LsVTeCTuRBo17, 2:48 AM 1/1/2003]
It shouldn't overheat unless your cooling system is jacked up. I have an 88 and it only overheated when something wasn't working right. Check fan, thermostat, coolant, radiator cap, and radiator for any faults.
