Has anyone else had this problem? (B18C1 distributer)
Old Jun 18, 2004 | 11:33 PM
*Boostwerks*'s Avatar
Default Has anyone else had this problem? (B18C1 distributer)
I'm not a happy camper...
I installed my brand new honda distributer into my B18C1 a while back and didn't really have any problems other than the fact it was a little snug going in the cam. I installed it exactly how the Helms shows it (with the slot on the key aligned with the machined back housing).
We tried starting it for the first time 2 days ago...Result?
The timing belt jumped the intake cam gear because the Distributer was binding the cam. I prayed to god the pistons didn't hit intake valves (fully rebuilt JG ported head)...but we did a compression test today. 1-4...130...130...125...0.
Pulled the head and its now at my machine shop awaiting new Ferra valves for #4.
To remidy this problem, I just took off the snap ring on the distributer key and turned it 180 degrees so the line is on the other side (opposite from what my helms says ).
To make a long story short...
This whole problem could have been avoided if either a) the key was machined correctly or b) helms actually gave you the correct information.
Old Jun 18, 2004 | 11:42 PM
Rod.'s Avatar
Default Re: Has anyone else had this problem? (Bryson)
hmmm...intresting. I just got a new dizzy also i am going to go check now
Old Jun 18, 2004 | 11:57 PM
Its funny how they are supposed to machine the key so you can't install it the wrong way...yet mine bolted in just fine.
Old Jun 19, 2004 | 01:57 AM
Turbo E's Avatar
that is some weird shiet. it IS supposed to be foolproof.
Old Jun 20, 2004 | 07:17 PM
Default Re: (Turbo E 604)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo E 604 &raquo;</TD></TR><TR><TD CLASS="quote">that is some weird shiet. it IS supposed to be foolproof.</TD></TR></TABLE>
Thats what I thought too...
Old Jun 20, 2004 | 08:02 PM
BLiMP's Avatar
Ya when i first bought my motor i decided to do some tune up work. I was getting ready to do a timing belt, so i turned the motor over a couple times. I found out that the cam marks weren't lining up. The distributor was broken and jumped the intake cam a couple teeth. Luckily I just needed a new distributor and my valves didn't get broken, well i don't think so. The motor started up fine.
Old Jun 20, 2004 | 08:09 PM
I do have to admit though...that it was pretty sweet to see a huge flame shoot out the intake manifold...
Old Jun 20, 2004 | 09:09 PM
ScottEK's Avatar
Default Re: (Bryson)
I was working with a friend once and I didn't even think to tell him how to put on the distributor. It is very possible to put the distributor on 180 degrees off, while he was trying to start it I watched as the distributor wobbled up and down binding the cam. It was pretty ugly, I had to replace the keyed end of the distributor.
Old Jun 21, 2004 | 04:42 AM
tony1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bryson &raquo;</TD></TR><TR><TD CLASS="quote">it was a little snug going in the cam.
It was snug because you put it in backwards, you don't line up the mark to the distributor, you offset the tabs to the same side the cam is offset. Simple mistake, i've seen it happen a few times, but don't blame anybody else...
Old Jun 21, 2004 | 03:19 PM
liam821's Avatar
25 Year Member
Default Re: Has anyone else had this problem? (tony1)
that sucks! thats not supposted to happened.
liam
Old Jun 21, 2004 | 03:28 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">
It was snug because you put it in backwards, you don't line up the mark to the distributor, you offset the tabs to the same side the cam is offset. Simple mistake, i've seen it happen a few times, but don't blame anybody else...</TD></TR></TABLE>
Well...for once, I'm kinda sorry that I refered to the book on this one.
Jasebring
Jun 19, 2023 07:53 PM
im_inn0c3nt
Jul 11, 2009 11:54 PM
petecivic
Apr 7, 2009 09:40 PM
elikas
Dec 5, 2006 08:35 PM
hatchedeg
Jun 5, 2006 07:53 PM
