hard to start with vafc hack.
Old Sep 27, 2002 | 09:00 PM
Ivan's Avatar
senior gold member
Default hard to start with vafc hack.
Topic says it all. Does anybody have a clue what it could be? Any help will be appreciated.
Old Sep 27, 2002 | 09:29 PM
Smashback's Avatar
Default Re: hard to start with vafc hack. (Ivan)
Probably too rich or lean. Mine was the same way until I got the fuel pressure and afc settings perfected....each car is different!
Old Sep 27, 2002 | 09:32 PM
Ivan's Avatar
senior gold member
Default Re: hard to start with vafc hack. (Hatchblack)
I tried fixing it by playing with the vafc. I guess I need to keep at it till I get it right. On another note, my clutch is slipping bad. What clutch do you guys reccomend?
Old Sep 27, 2002 | 11:23 PM
filetofit
Guest
Posts: n/a
You need to add fuel at idle. Try a -20% cut at idle and -40% everywhere else.
Clutch, Action Stage 2 KS =
[Modified by filetofit, 8:24 AM 9/28/2002]
Old Sep 28, 2002 | 12:17 AM
shadowdawn's Avatar
Default Re: hard to start with vafc hack. (filetofit)
I love the afc hack.... but because of it I have a code 13 ALL the time, reset it and it just comes back.... its not MAP code but BARO code, hopefully when I goto the dyno tomorrow and tweak out my afc settings it will go away.... but if not I'll just have to wait till I convert to obd1 and hopefully it will go away then.
Old Sep 28, 2002 | 12:22 AM
filetofit
Guest
Posts: n/a
Default Re: hard to start with vafc hack. (shadowdawn)
hmmm, what does the BARO code mean? Does it have to do with the barometric pressure sensor built into the ECU. I don't understand why the hack would affect that. How's the idle? What kind of a cut are you running at idle?
Old Sep 28, 2002 | 12:44 AM
shadowdawn's Avatar
Yes baro meaning sensor in ecu. It makes somewhat sense because the ecu takes the baro reading and the map reading and if they are WAY different then the ecu thinks the baro is broken... dunno why I would trip it even knowing this but...
Idle and driving is perfect. Cut was at first -35% at 1000rpms and -40% for the rest but now is about:
1000rpm is -36%
2000rpm is -38%
3000rpm is -38%
4000rpm is -36%
5000rpm is -36%
6000rpm is -36%
7000rpm is -36%
8000rpm is -36%
both hi and lo
ZzZCivicZzZ
Jul 28, 2006 10:52 PM
superturboprelude
Nov 4, 2004 05:39 PM
neo1z
Oct 7, 2003 11:01 PM
PrecisionH23a
Sep 17, 2002 10:24 AM
