Hallman boost controllers, any experience w/ these?
Old Nov 14, 2002 | 10:10 PM
D16A6Turbo's Avatar
Default Hallman boost controllers, any experience w/ these?
I'm trying to find a MBC more accurate than my basic TurboXS. Got this web page from the latest Turbo Mag:
http://www.boostcontroller.com/
the ceramic ball and spring sounds like a cool set-up...any experiences w/ this company?
Old Nov 14, 2002 | 11:16 PM
IntegD's Avatar
New User
Default Re: Hallman boost controllers, any experience w/ these? (D16A6Turbo)
Just got mine in the mail today. It doesnt look too bad. I think it will work pretty nicely. I read a ton of threads on it in the search function..just check 'em out there...
Old Nov 15, 2002 | 12:14 AM
SIK IN DA HED's Avatar
New User
Default Re: Hallman boost controllers, any experience w/ these? (IntegD)
hallman and joeP boost controllers are 2 of the best out there for the price.
Old Nov 15, 2002 | 01:33 AM
Etylorcen's Avatar
Default Re: Hallman boost controllers, any experience w/ these? (dlplayboy)
Old Nov 15, 2002 | 05:26 AM
D16A6Turbo's Avatar
itegd, which model did you end up getting? I'm thinking about the ceramic ball one you can adjust from the cockpit...
Old Nov 15, 2002 | 05:34 AM
bgod's Avatar
used to run the joep. mbc on my h22a turbo accord.
never let me down. held boost perfectly with a tial 35mm wastegate.
Old Nov 15, 2002 | 07:41 PM
IntegD's Avatar
New User
Default Re: Hallman boost controllers, any experience w/ these? (bgod)
I got the one with the dial on the controller itself. It was the 50 dollar one. I am just gonna tune the hondata with whatever boost I feel good with and keep it at that.
Old Nov 15, 2002 | 08:49 PM
gritsak's Avatar
i used to have a hallman mbc on my supra...very simple to use (just turn a ****) and held boost better then my my previous electronic controller (hks evc ez, which is regarded the best electronic boost controller for mkiv) it held over 2bar with no spikes or creeping what so ever.
Old Nov 16, 2002 | 08:38 AM
D16A6Turbo's Avatar
Default Re: Hallman boost controllers, any experience w/ these? (gritsak)
O.K., I just ordered one w/ the steel ball and cockpit controller (that's gonna be so convenient). I'll let you guys know how it performs when I get it...
Old Nov 17, 2002 | 06:24 AM
integra-modder's Avatar
I wonder if there is a way to make a DIY Hallman MBC?
Can anyone get closer pictures of the components, I want to see if they have anything of the like at Home Depot, Lowes, or any other hardware store around my house.
Old Nov 17, 2002 | 06:28 AM
teamrocket si's Avatar
I have one, and it works well for 40 bucks.
Old Dec 15, 2002 | 09:10 PM
D16A6Turbo's Avatar
Default Re: Hallman boost controllers, any experience w/ these? (teamrocket si)
I've had my new Hallman MBC for a couple of weeks now (w/ cockpit adjustment)...and it's probably one of the best investments I've made...
I'm set at 12psi and holds boost pretty darn good...no noticable spiking...
I'm now spoiled...controlling boost from inside the cockpit is a BIG plus, you don't know how many times I would of had to stop open the hood and turn the MBC. The Hallman unit is very touchy and only incremental turns are necessary to make adjustments. Again, get the cockpit adjuster!!!
Old Dec 15, 2002 | 09:46 PM
accordfreak's Avatar
do you have any pictures? what does the cockpit adjustment look like installed in your car? How does it exactly work?
Old Dec 16, 2002 | 09:41 PM
D16A6Turbo's Avatar
Default Re: Hallman boost controllers, any experience w/ these? (accordfreak)
accordfreak, as of now, I have no resources to post pictures(sorry). But to answer your question, the cockpit adjustment is a round **** about 1-1/2" in diameter w/ a white dot for indexing (nothing pretty, just get's the job done). I've mounted it through a spare accessory square just below my stock guages and have the adjustment cable running through the firewall at the same location my speedo comes through. The actual controller is mounted on the front of the engine compartment close the the radiator, I think it's about 5' of cable that they give you to route. I may be getting a digital camera soon and will post pictures if I get it...turning the controller clockwise lowers boost and raises boost as it is turned counterclockwise...
91accordex16
Jun 23, 2005 02:51 AM
SOHC_MShue
Mar 14, 2005 03:00 PM
White_Comet_Of_Akagi
May 19, 2004 05:18 AM
lvf03
Mar 13, 2004 01:57 PM
95GS-R-N.O.S
Oct 24, 2003 04:52 PM
