the hack on 370's???
Old Oct 22, 2003 | 06:12 PM
kell211's Avatar
Default the hack on 370's???
i'm going to take my car out tomorrow to try and tune it the stupid way, on the drag strip. i'm acually ony going to try and get it running to about 6psi. i'm attempting to set up the equivelant of an vafc hack using an emanage and the profec e-01. i've got 370 injectors instead of the 450's usually recommended.
any advice on what to look for? i'm going to be doing major experimentation with the negative amount to set the injectors at, but i'm pretty sure i'll be able to set it to run equally. anybody out there have any experience with any of this, or any ideas on what i should be looking for? i figure pulling the plugs between runs will be the best representation of what's acually going on in the motor.
if anyone has any experience setting up the hack with an emanage and e-01 i would appreciate advice, and/or if anyone has ran the hack with 370's. i just want to know the boost capabilities of 370's without throwing the cel. to equal 450's i'll be running -27% up to -21% at high rpm's if my math is right. will this throw a cel for sure? since 450's throw it somewhere around 30% to 35%?
any advice is appreciated.
Old Oct 22, 2003 | 06:17 PM
Mr.DC2TurBo's Avatar
Default Re: the hack on 370's??? (kell211)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kell211 &raquo;</TD></TR><TR><TD CLASS="quote">i'm going to take my car out tomorrow to try and tune it the stupid way, on the drag strip. i'm acually ony going to try and get it running to about 6psi. i'm attempting to set up the equivelant of an vafc hack using an emanage and the profec e-01. i've got 370 injectors instead of the 450's usually recommended.
any advice is appreciated.</TD></TR></TABLE>
actually I'm boosting using 440cc with s-afc at -30 to -25 and you should be fine.
Old Oct 23, 2003 | 03:13 AM
kell211's Avatar
440's at -30% to -25% is way richer than what i'm talking about running. anybody done the hack on 370's, and what kind of success did you have?
rhdjitsu
Mar 22, 2006 06:10 AM
DRIVENRacing
May 27, 2004 08:22 PM
Mr_Bojangles
Apr 28, 2004 07:43 PM
1.8T_EG
Dec 9, 2003 09:11 PM
zojirushi
Sep 3, 2002 09:20 PM
