Engine light
Old Dec 23, 2013 | 12:17 PM
Kenneth77488's Avatar
Default Engine light
Can't start my 1993 honda civic till the engine light turns off and then the fuel pump kicks in...email me please to kennethmartinez77488@gmail.com if you can help
Old Dec 23, 2013 | 12:29 PM
kyden's Avatar
Default Re: Engine light
check your main relay.
Old Dec 23, 2013 | 02:06 PM
honda1977's Avatar
Engine oil pressure switch may be euchered too , as it will cause the gas pump to stop pumping under low oil pressure ...
Old Dec 23, 2013 | 02:17 PM
fcm's Avatar
fcm
Old Fart
As mentioned, check the PGM-FI Main Relay, the fuel pump relay in the PGM-FI Main Relay and the ECU/ECM control the fuel pump.
The fuel pump should turn on, [to prime for a few sec.] as soon as you turn on the ign. switch, if it does not then you either have a problem with the PGM-FI Main Relay or the ECU/ECM. 94
oresama
31
Jan 19, 2025 10:47 PM
jerome^galon
Jan 4, 2012 07:03 PM
ls_vtec_da
May 7, 2011 09:05 PM
ghettoda9
Apr 13, 2011 10:03 AM
madmax94
Feb 28, 2011 02:03 AM
