h22 wont idle
Old Jul 8, 2013 | 04:20 AM
Big Rhag's Avatar
Default h22 wont idle
hi just did an h22 swap on my accord and it wont idle at all and i have to advance the timing all the way for it to starts and rev and its running really rich
I did a vacuum test and it says i have slow timing but i cant advance the timing anymore need help please
Old Jul 8, 2013 | 04:27 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: h22 wont idle
Have you checked that the throttle body stop is in the right spot and closes properly/doesn't stick/bind?
Also check the idle air valve, it might need to be cleaned.
But advancing timing like that normally means a vacuum leak
Here's a simple way to tell
Take a can of brake cleaner and spray it at every mounting flange/gasket area, any where along the intake tract where there could be a leak. If you have one the rpm will climb as the motor burns the solvents
Is this motor na or boosted?
Stock ecu?
Bigger injectors?
We need a detailed list of what's been done... modifications, etc to be able to help you properly
Old Jul 8, 2013 | 05:20 AM
Big Rhag's Avatar
Stock ecu?
Bigger injectors?
im running turbo camshaft low cp piston the ecu i a p28 chipped stock injectors its starts and rev fine but as soon as i let go of the throttle it will stall and thank for the reply
Old Jul 8, 2013 | 05:26 AM
Big Rhag's Avatar
and how do i do the vacuum leak test since it doesnt idle i get a friend to hold the rev while i do it?
Old Jul 9, 2013 | 04:58 AM
Big Rhag's Avatar
fixed the prob the timing wa off by one teeth now she is idle but a bit high im going to play with the idle screw to fix it
Old Jul 9, 2013 | 07:20 AM
snobordboy's Avatar
Moderator
That was going to be my guess, glad you found it!
Old Jul 9, 2013 | 07:44 PM
Big Rhag's Avatar
thanks the idling screw didnt help at all so i retarded the ignition timing and idle went normal :D
JasonST
Apr 8, 2012 11:52 PM
boostedjdmdc2
Dec 24, 2007 03:38 PM
dek1mfk
Nov 20, 2006 02:56 PM
jdmjonnyacc
Apr 26, 2006 10:13 PM
Knightmare69
Dec 17, 2003 08:44 AM
