H22 turbo help?
Old Aug 5, 2003 | 02:33 PM
h22hatchypatch's Avatar
Default H22 turbo help?
I need help really bad. I have a 92 si hatch with an h22/turbo. My problem consists of ......when i drive and it starts boosting up ....around 5000rpm or some....it starts to bog and jerk...until i change gears and so on so forth same deal. So i took the intake piping off to see if does it when i have N/A....well when i hit bout 5500(give or take).....same stuff.....drives normally until i hit that rpm and it starts to break up...or so.....kinda like a stutter box or so. I have no check engine lights on....had knock sensor but some what took car or that.
My set up-----H22a, turbonetics t03/04. waistgate, msd ign, blaster coil, stock head, stock injectors, holley FP, vortech fmu, aeromotive FPG, p13 ecu with missing link on map sensor, 3 bar map.
Any help would greatly be appreciated because this mess is certainly getting on my last nerves.
Thank you
Pat
Old Aug 5, 2003 | 02:39 PM
speedworks's Avatar
Default Re: H22 turbo help? (h22hatchypatch)
what ratio disc are you using in your fmu
Old Aug 5, 2003 | 02:44 PM
Default Re: H22 turbo help? (speedworks)
i got a 10:1
im running 9lbs of boost by the way
Modified by h22hatchypatch at 4:30 AM 8/6/2003
tensaiwung
Apr 28, 2011 05:38 AM
95boostedh22
Jan 27, 2008 08:54 PM
tcontesh
Apr 24, 2006 07:04 PM
Jeter2karaffa
Sep 5, 2005 06:02 AM
davasmaximus
May 1, 2003 01:42 PM
